Your Custom Paintjobs
Very nice. I like the skulls. Have thought about picking up a template to try them myself
Went with a few of the guys I race with to do a demostration of our R/C's at a local school. I brought my airbrush and compressor and did this up quickly. It's hard to concentrate with 200 screaming children in a gym.
Caster Body
Detailing on the side Createx Pearl Red on a Opaque Red background, so they fade in nicely until viewed at the right angle. The top is a heavy coat of Pearl Silver backed in a light coat of copper. Detail on the top is a very light coat of copper. Everything is then backed in white. Simple, but I only had 30 minutes.
Caster Body
Thank you, template I used was the Mini Skullmaster.
New Paint
copied from this
For a Buddies son his first time out running a full season. He likes Blue and Green and the number 88
This one is just because I saw a car done with stars but it was not a good picture
copied from this
Jim, Thanks
The Buggies look Great ! Great Job on the rips !
Great Combination of Rips, Checkers and Drips withou making it overloaded, Thumbs Up !
Frank, no problem, thanks!
Blacktiger355, nice work. If you want to make the stencils look less "stencily" just hit the outer edges of each skull in a circle pattern with the shading color a little bit before spraying in the background color. Only takes a minute and the difference is worth it.
This will give them a little depth. You can even do some where you make the eyes red, or blue and the teeth white, but most of the time it blows the budget for a race body.
Best of luck!
Jim
W.E.D.
www.wedjim.com
Best of luck!
Jim
W.E.D.
www.wedjim.com
Thanks for the tip Jim. I did that a little between the two areas of the stencil I used. I will try some more edge smoothing next time.
[QUOTE=dodgeboy;9140028]New Paint
copied from this
What scale is the McLaren?
copied from this
...'cause it'll never look this good again...
Two of my latest... I didn't pick the colors on either of these ones:
CPT America...those look very clean and sharp. Good stuff.
Here's one i did for a local guy
new body I did on my 22
