what do you guys know about running high octane fuel??
like 100 octane on a 30cc engine will it give me more power?
Not alone. To benefit from the higher octane rating the engine got to be highly tuned and the compression need to be raised and maybe you have to use adjustable timing. With that said, i am not a motor guru, i just write what i have read from other discussions about this topic.
It will give you a little more power,not a lot
Well for me, I don't race in an organized level with money to be won in the end. So I don't consider running these expensive race fuels. I would however experiment with some old VP race fuel if I had an extra gallon or so. For now, I never took the time to try it.
Originally Posted by BIZCO-RC
(Post 9158658)
Some fuels, like quite a few of the VP lineup are oxygenated fuels, which is a whole different discussion. Many of which will yield good gains, and there's generally good information on the website about what their fuels were designed for and the engine parameters needed. |
top response ridley.
unless the motor is built and tuned to run on high octane there will be no benifits, only drawbacks such as higher running temps etc. these motors are desinged to be run on regular, with compression ratio's to match. |
My experience may be a little different than most of you, but it should be relevant nonetheless. I dont have a large scale RC, but I used to own a mostly stock Martin Monster 23cc scooter and I have run high octane fuel in it with amazing results. Results based on a cheap Bushnell radar gun, tuning the mixture on the fly for each run, with several passes for a fair average.
Pump 87 octane+Tech 2000 2-cycle oil+Me= 23mph top speed VP 118 octane+Royal Purple 2-cycle oil+Me= 27mph top speed Out of all passes the smallest difference was 3mph, average of 4mph difference from several passes. This might not seem like much, but dont forget it was carrying me, at 190lbs. I imagine in a RC, this could translate into much larger gains. As a certified auto tech, I have always understood the same theory that Ridley has posted above. But experience tells me the engine manufacturer may not always have it right, and it might be worth a shot. I have seen some full size cars experience large gains in fuel efficiency and power from higher octane fuel when the manufacturer recommended 87. Yet other cars have shown zero benefit from the same treatment. As I said, not necessarily a direct comparison here, but it should be relevant to the discussion. |
wow that is interesting! big jump in mph but also big jump in octane, down here regular is 91RON and the the high po pump stuff is 98RON so not that big a difference./
Originally Posted by sperera
(Post 9192871)
E.g. G290? I've always ran the BP ultimate 98 as I thought it would be better for the motor in the long run. What do you guys think? Cheers |
(Post 9158658)
Our cars never have any problems with vapor lock or fouling the plug. |
Originally Posted by burnineyes
(Post 9192595)
Pump 87 octane+Tech 2000 2-cycle oil+Me= 23mph top speed VP 118 octane+Royal Purple 2-cycle oil+Me= 27mph top speed Out of all passes the smallest difference was 3mph, average of 4mph difference from several passes. This might not seem like much, but dont forget it was carrying me, at 190lbs. I imagine in a RC, this could translate into much larger gains. As a certified auto tech, I have always understood the same theory that Ridley has posted above. But experience tells me the engine manufacturer may not always have it right, and it might be worth a shot. I have seen some full size cars experience large gains in fuel efficiency and power from higher octane fuel when the manufacturer recommended 87. Yet other cars have shown zero benefit from the same treatment. As I said, not necessarily a direct comparison here, but it should be relevant to the discussion. Oh, and not to mention pump gas is all 10% ethanol now, which makes it have less energy per volume, and generally run poorly in 2 strokes. Most race gas is pure gasoline, so that gives a modest gain right off the top. For the little amount of fuel that one goes through in rc cars, you might as well bite the bullet and buy a 50$ 5 gallon can of good VP fuel. If nothing else, it smells SOOO good ;) |
Originally Posted by Ridley
(Post 9183333)
High octane gas will actually reduce the power. The lowest octane gas you can run that doesn't pre-detonate will yield the most power. To need high octane gas you must have a high enough compression to cause normal gas to pre-detonate. Octane in itself doesn't increase power, only changes the requirements for that fuel to burn completely.
Some fuels, like quite a few of the VP lineup are oxygenated fuels, which is a whole different discussion. Many of which will yield good gains, and there's generally good information on the website about what their fuels were designed for and the engine parameters needed. However I run Sunoco... Just cause it smells good. LOL |
(Post 9192595)
Pump 87 octane+Tech 2000 2-cycle oil+Me= 23mph top speed VP 118 octane+Royal Purple 2-cycle oil+Me= 27mph top speed Out of all passes the smallest difference was 3mph, average of 4mph difference from several passes. This might not seem like much, but dont forget it was carrying me, at 190lbs. I imagine in a RC, this could translate into much larger gains. As a certified auto tech, I have always understood the same theory that Ridley has posted above. But experience tells me the engine manufacturer may not always have it right, and it might be worth a shot. I have seen some full size cars experience large gains in fuel efficiency and power from higher octane fuel when the manufacturer recommended 87. Yet other cars have shown zero benefit from the same treatment. As I said, not necessarily a direct comparison here, but it should be relevant to the discussion. http://www.lucasoil.com/images/produ...l__16oz_lg.gif Semi-Synthetic 2-Cycle High Temp Racing Oil This product is a "low smoke" two-cycle oil formulated from a special blend of mineral oil, polybutene and a low ash additive system. Lucas 2-Cycle Racing Oil is specially designed to prevent carbon deposits to the piston rings, skirt, crown and under crown areas and prevent exhaust port blocking. It is prediluted with a special solvent to facilitate mixing with gasolines at all temperatures. Lucas 2-Cycle Racing Oil is recommended for all air and liquid cooled two-stroke engines and lower specific output air-cooled engines functioning under all operating conditions. Meets the requirement for "low smoke" oils often referred to as "smokeless" oils. Designed primarily for use with oil injection systems where no fuel/oil premixing is required. However, it is also acceptable for use in premixes of gasoline and oil up to 50:1. Key Benefits .Prevents carbon deposits .Mixes well with gasolines at all temperatures .Meets requirements for "low smoke" oils |
Lucas makes a good product . I was going to try some but I am having a hard time trying something new. I run Redline Racing 2 stroke in every 2 stroke I own and have for years.
Oops. Wrong thread.. Nevermind.
