Baja 5T Help!!!
Baja 5T Help!!!
Hey all - Just bought my 5T today and ran for 10 min. before breaking a dogbone. Got fixed at the lhs and now my receiver is flashing "LED" and I can't control any of the servos. Does anyone know what to do to get the controller and receiver "talking again"??????? frusterated with first day to be sure
Suspended
you need to charge the battery on the RX. the stock 2000 mah packs are good for about a tank or a bit more. the 3000 mah will make 2 or so tanks.
the blinking red light is typically a sing of low rx power, though it can mean loss of radio signal.
recharge the rx pack and try it.
leaking fuel question
is it normal for my baja to have leaked out some fuel during a light roll over? i rolled it yesterday and at the base of the airfilter near the tank (changed fuel ,return line and clunk filter about a month ago))the air filter was soaked with gas .i ordered a new carb yest and when i install it ill check the fuel line for leaks.what else could be leaking?
Thanks everyone. I will give it a try and see if I can get it going. I think it might be fail safe plus battery for the receiver. will charge and find out.
keep us updated
