HPI Super Electric RS4's W/Brushless system
#526
Hello guys. I have 2 Super RS4 and want to make one of them a drift. I have MambaMax 7700 for the one and one Novak unlimited ESC with brushed 3x13 turns motor. The last one is too weak for this big model and want to make it drifter. Can you suggest me 280 or 300mm wheelbase should I use? What are the + and - of bigger wheeelbase? I'll not race with them, all is just for fun.
Thanks a lot.
Stanislav
Thanks a lot.
Stanislav
#527
Thanks a lot.
Stanislav
Thanks a lot.
Stanislav
Check out 1:34 of this video for an idea:
+ YouTube Video | |
#528
Thanks for fast answering. I dont know should I remove the front belf or not.
... its easier to remove the dogbones just for the try. If I see good result, will remove the belt. I preffer to skip the belt removing because one of the RS4(the one I want to make drift) is very very used and screws cant tighten right. I have Murcielago and GT1 bodies and thats why I wounder which base should I use. Any other suggestions will be welcome.
I cant post videos and pics here, cos of my rating...
Thanks again.
Thanks again.
#529
gear shaft for original RS4
My bro has the original single belt RS4 and he has snapped his gear shaft. This seems like a common problem from what I have read.
The part number is A190 but it is discontinued and we can't find one apart from in an expensive bundle on ebay.
Does anyone know if some of the similar parts like the A191 or A192 etc can be adapted to work?
Many thanks for any assistance that can be given.
Regards,
David.
Regards,
David.
#530
Regards,
David.
Regards,
David.
#531
I think Davids problem is different.
The Original RS4 uses the single belt for the front drive only. The rear is driven from a gear drive train from the layshaft, similar to the way a 2WD offroad drivetrain is working.
From what I understand the layshaft is broken or another gearshaft from the other reardrive gears.
I think it will be very difficult getting that shaft somewhere. Maybe Ebay will be the only option. But you could try at Ebay in different countries. When I was searching a oneway for the Super RS4 (after this was discontinued) I finally found one in Australia if I remember right.
I will ask some friends if they have left something from their old HPI cars.
#532
David, I am not sure what you can do with the RS4. Can you switch out a drive gear to help accommodate the other belts you mentioned? There is a company in the UK called Wheelspin that might have your belt--it is worth a try. Another option I have for you requires a little bit of effort. There is a company called Stock Drive Parts (SDP), look them on the web, they have belts for all types of applications. I can just about guarantee you will find your belt in their catalog--except it will not have a HPI part#!
Cheers,
David.
#533
Thanks for the help guys. Yeah my bro's problem is like V12 said the actual shaft it'self. My bro bought a bundle of rs4 parts but they were from a RS4 MT so they don't fit of course. I'm thinking he needs the actual part or to do the twin belt conversion that I have read about.
Cheers,
David.
Cheers,
David.
#535
Regards,
David.
Regards,
David.
#538
Re: HPI Super RS4 EP Chassis Set
Hi! The chassis set you have is made of fiberglass or carbon graphite? Can you upload some hi-resolution pictures please? Thanks.
Hi, we will be offering a graphite chassis for the super. it will be 3mm thick chassis, 2.5mm thick top plate with 3mm thick shock towers. kit will cost around $95.00
if you want info please email me at [email protected]
thanks
thanks
