2 cycle oil
Once you are done with the break-in process you can use 32:1 which comes to 4 oz even.
Some people go all the way down to 50:1 which is 2.56 oz of oil.
So the less oil you use the move performance you get, but at the expense of durability.
I've been having good luck with Klotz Supertechni plate synthetic oil at 25:1 for my 5T. Smells great to!
Amsoil dominator
Suspended
ive used the AmsOil Pro Saber 100:1 at 25:1 to 50:1 with good results. but it had no to little smell to it. near zero smoke.
i ran Koltz Supertechnoplate. had a decent smell, but was very dirty inside.
ran from 25:1 to 40:1.
i then made the switch to the Maxima Castor 927 or Super M when i cant get the 927. the 927 has a great smell, nearly zero smoke, and my motors are very clean. mixing 25:1 to 32:1 with it.
same with the SuperM but it has less smell and is a full synth.
25:1 to 40:1 should do you very well.
Trader Rating: 25 (100%+)
The FG team of Bob Sarnelle and Frank Killam have been using NEO oil with great success for years. It's all I"ve used for the last year--it works great.
T
T
You might wanna check that out, the 2cycle's are being done away with in the US because of the EPA, check out most your new weedeaters alot are 4 stroke, lawnboy also is now 4 stroke, and all most every new dirt bike is 4 stroke, even outboard boat motors.
So before you roll your eye's read what the EPA says about the death of 2 stroke motors in the states, and along with the 2 strokes the oil's that they mix in also
