Xceed pipe cleaner
Old 10-11-2016 | 06:28 AM
choisan's Avatar
Default Xceed pipe cleaner
Anyone tried the xceed pipe cleaner to clean your exhaust pipe, it was quite useful. After dipping and rinsing, the pipe was restored to its original shines.
But the chemical itself is very acidic, very dangerous to use.
Does anyone know what acid it is? Someone said it is hydrofluoric acid.
choisan is offline
Old 10-11-2016 | 09:11 AM
I just wipe my pipe after each run with a bit of cloth with the fuel on. Takes off the dirt and leaves it nice and clean with minimal expense.
James73 is offline
Old 10-11-2016 | 10:55 AM
lil-bump's Avatar
Carbon-off it's an industrial oven cleaner. Pretty strong stuff.
lil-bump is offline
Old 10-11-2016 | 01:48 PM
I am using creolin to clean my pipes. Just put them in there for a couple hours and then rinse them while cleaning with a sponge.
thommi is offline
Old 10-11-2016 | 04:40 PM
https://www.walmart.com/ip/RUST-OLEU...&wl13=&veh=sem
Thats what I use
nitrodude is offline
Old 10-11-2016 | 06:45 PM
choisan's Avatar
Thanks, I used Carbon off before, I saw the xceed and want to try it.
People using it, just dip the pipe in, I believe for less than 10, 20 mins, the things just off from the pipe.
But it's very acidic. Need to wear a pair of industrial gloves and use next to the tap.
I was told a guy who used this, spilled over his skin, he needed to have Skin implantation.
Highly corrosive.
choisan is offline
Old 11-09-2016 | 09:11 PM
radiator coolant nulon /not mixed and mums slow cooker just through it in //in one piece and it will come out with all the numbers still on it lasted 3/4 years make sure lid is on and not in bed room/ha
greg.dawn is offline
Old 11-10-2016 | 09:15 AM
I still use this method as well. Just some radiator coolant (commonly known as antifreeze in the USA) and a crock pot. I went and bought a cheap crock pot for this purpose. Works well enough for me.
Scott Fisher is offline
Old 11-10-2016 | 12:49 PM
as mentioned, easiest and cheapest way is creolin. no heating up things, nothing... just put the pipe and stuff in it for a while, then rinse it...
thommi is offline
Old 11-10-2016 | 02:08 PM
That stuff smells bad though
Old 11-10-2016 | 02:41 PM
so does antifreez when a friend does it in is basement lmao...
TrespasseR_MN is offline
Old 11-30-2016 | 04:41 PM
I donot have any spiders in the garage any more but the garage is down the back
