-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   See through engine bearing? (https://www.rctech.net/forum/onroad-nitro-engine-zone/962313-see-through-engine-bearing.html)
mustangkillaz 09-18-2016 09:24 PM
I ordered an outter bearing for one of my .12's, I can see light coming through the outside seal, the factory nova can't be seen through. Acer says no one else has had an issue, but I see this thing leaking.
Thoughts, experience with acer?
Tia
Roelof 09-18-2016 10:46 PM
Even the light tight seals do leak. The seal is not for keeping the oil inside, there is a small system in the crankcase working with a slot in the crankshaft working as a seal.
mustangkillaz 09-21-2016 08:52 PM
Gonna use a novarossi and be done with it. And yes, even factory bearings seep a bit.
