tools for engine mods
#16
hiya guys!
what kind of epoxy do i use to lighten the crankshaft?
i see that its orange in color and on certain engines it actually feels a little soft.
is it RTV silicon or epoxy?
and if so, which one exactly?
thanks gor help!
merry christmas and happy holidays!
-alexander
thanks gor help!
-alexander
#18
Originally Posted by Ridder
Hmmmm...I always thought the silicone was to smoothen the gasflow through the crankshaft.
But I can be wrong: never modded an engine.
Mark
#21
if you are modifying the crank, none of the carbide metal bits are strong enough, or sharp enough to modify a crank. you need to use a stone bit. (i use the green stone bits made by dremel. these are the hardest stone bits available. you need to use this.
ALSO ALWAYS USE PROTECTIVE EYEWEAR!! IF YOU DON'T HAVE IT, GO BUY SOME. NEVER DREMEL WITHOUT IT!
for eye wearl i use the full face masks, these are better, because when you use a wire brush to eventually polish the crank parts you moded the steel brush peices tend to fling of.
ALSO, USE AUTOSOL, OR ANY METAL POLISH FROM THE CAR SECTION TO POLISH THE CRANK AND BRASS SECTION OF THE SLEVE.
#22
Originally Posted by foampervert
hiya folks,
ok, we now know its for lightening the crank, what KIND of Epoxy or silicon is used for the crank lightening?
does anyone know?
-alexander
does anyone know?
-alexander
Your answer......NONE. Because you cant add something and expect it to make it lightweight.
Its the GRINDING that makes it lightweight. The epoxy is for making the air flow smoother as everyone answered.
#23
hiya Artificial-I and others!
thats not what i meant, i am not thick.
my query is:
does anyone know WHAT epoxy or silicon( specifically; i.e. JB weld or dow corning's RTV silicone or what?) is used to smooth the airflow in a drilled/ground out crankshaft?
i do understand that the epoxy or silicon is used to smooth the air flow after the shaft lightening process. i just wanna know what is being used.
thanks to all!
-alexander
my query is:
thanks to all!
-alexander
