Old 09-20-2005, 10:26 PM   #1
SRAD's Avatar
Default AAC engine break-in
I know it's probably been asked or discussed a few times on here but I didn't know what to ask for in the search engine....so here goes. Picked up a Collari AAC motor (.21 onroad)new(but no instructions or box)....is there any difference in the break-in procedure for these AAC types versus ABC type engines? I've never owned an AAC engine and I want to make sure I break it in right? Thanks
SRAD is offline   Reply With Quote
Old 09-22-2005, 09:54 AM   #2
SRAD's Avatar
Default RE
Come on guys....someone has to know about breaking in one of these engines. Chime in here!!
Old 09-22-2005, 11:27 AM   #3
EdwardN's Avatar
The same way as ABC. AAC is very good set up for really cold weather and acting strange in hot ambient. I try it in the past and RC cars is not perfect aplication for AAC. Also 21 engines has too many ports and there is high posabilities that bridges between ports will brak-it happened many times in the past.
Edward
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 09-23-2005, 09:48 PM   #4
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
What does AAC stand for? What are the advantages of an AAC engine?
Sean
Team Duratrax is offline   Reply With Quote
Old 09-28-2005, 03:30 PM   #5
duneland's Avatar
Alum piston-Alum sleave-Chrome plated sleave.
V.S. Alum piston-Brass sleave-Chrome plated sleave.
AAC is lighter. Originally developed with the idea that the expansion rate would be the same between piston and liner. Thereby maintaining compression when engine hit temp.
duneland is offline   Reply With Quote
How not to break in an engine ! Maximo Nitro Off-Road 4 08-05-2008 10:34 PM
engine break in 37 RACING Nitro Off-Road 10 03-15-2008 03:25 PM
Engine break-in ? acsubie Electric Off-Road 3 05-11-2007 08:42 PM
How do you break in an engine? joe of loath Rookie Zone 12 03-26-2007 04:08 AM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 11:49 PM
