Like Tree1Likes
RB Engine Thread
Old 08-19-2007 | 03:07 PM
  #376
ziggy12345's Avatar
I checked on the RB website and the idle needle is 8 turns out!!
ziggy12345 is offline
Old 08-20-2007 | 01:47 AM
  #377
azcau's Avatar
Xenon is :
Main 6.5
Idle 8.0
http://www.rbproducts.com/explose/RB...121-001001.pdf
Xenon R is :
Main 6.5
Idle 5.5
http://www.rbproducts.com/explose/RB...121-001000.pdf
Links go to the respective manuals .
azcau is offline
Old 08-21-2007 | 02:58 AM
  #378
Pattojnr's Avatar
question on engine choice, i have been thinking of the speedline matrix rw and also the new R3. does enyone have recomendations as to which engine might be the better choice ? things to consider are fuel economy, power delivery and longetivity. thanksguys.
Pattojnr is offline
Old 08-21-2007 | 07:58 AM
  #379
Hey Patto. I'm currently running a Murnan Modified R3 with the novarossi 2630 pipe. I love it. I've only done two race days with it so far & I can feel it's still breaking in. I had more power this week than last and managed a 3rd place. It's still running fairly fat as I don't want to push it too hard early in it's life. Can't say about the matrix as I haven't run one yet. Also there is a separate thread on the R3 here as well.
GBagRacing is offline
Old 08-27-2007 | 09:59 AM
  #380
ziggy12345's Avatar
Originally Posted by azcau
Xenon is :
Main 6.5
Idle 8.0
Xenon R is :
Main 6.5
Idle 5.5
Which one is the better engine? I have the Xenon (not R)
Old 08-31-2007 | 07:41 AM
  #381
Does the RB WSII use/interchange with the WSIII?
samayoa is offline
Old 08-31-2007 | 05:10 PM
  #382
azcau's Avatar
The only difference as far as I know is that the Xenon is ABC construction and the Xenon R is AAC . I have the Xenon because I feel that ABC construction is more durable , but mine is stuffed now so what would I know !!!
azcau is offline
Old 07-19-2011 | 07:31 AM
  #383
TommyBlazin's Avatar
wow, this thread been in active for a long time, if there's a new one for the on-road motors please re-direct me there...
are the c9 c10 c11, the same, and more or less 35 plus 21's? thanks
TommyBlazin is offline
Old 07-19-2011 | 10:29 AM
  #384
Grinder's Avatar
The c11 is the better of the rb's you listed. It has a better piston material, and more rigid block than the older models. The rb is different than the 35+21. It has more crank timing, lighter crank, different block. The Rb has more top end than the 35+21. The 35+21, and Rb parts are not interchangeable without modification.
Grinder is offline
Old 07-19-2011 | 11:38 AM
  #385
bobbyblaze's Avatar
i got the classico10 and it a descent engine ..it came with the 3003 pipe imo the 2018 bring the engine to life..i got this engine because im sort of a newbie to onroad nut ready to upgrade to the C11 its look strong
bobbyblaze is offline
Old 07-19-2011 | 06:06 PM
  #386
so would you say the c9-c11 has more top end than a 35 plus 21 tuned? or just over the stock versions?....lastlly do nova pipes work w/rb motors, 2015 etc etc..thanks
also the c11 has a different p/s/r set than this?
http://www.amainhobbies.com/product_...Connecting-Rod
Old 07-19-2011 | 06:20 PM
  #387
Grinder's Avatar
Yes. They have more top end than the tuned 35+21. The novarossi 2015 pipe works great with the rb c11. I like the medium conical header with the 2015 on the c11.
Grinder is offline
Old 07-19-2011 | 06:43 PM
  #388
but thats the same p/s/r/ as all three c9-c11..unless the c11 has a different part number? i just wanted to see the different piston on the c11...
Old 07-19-2011 | 08:05 PM
  #389
Grinder's Avatar
The c10, and c11 have a lighter, more durable piston than the c9. I'm not sure of the part numbers without looking them up. The c10, c11 piston is definitely an improvement.
Grinder is offline
Old 07-25-2011 | 07:05 AM
  #390
gashuffer's Avatar
Will a Nova SCT crank drop into my TJ10?
gashuffer is offline
