Old 08-08-2005, 04:26 PM   #1
silacomalley's Avatar
Send a message via MSN to silacomalley
Default What % nitro for STS .28 engine?
I am upgrading my savy engine for an STS .28. What % nitro would be best to use? I currently use 20% on my star s-25. Should I stick to the same for the STS or Should I go higher?
silacomalley is offline   Reply With Quote
Old 08-09-2005, 10:35 AM   #2
Nitro Tech
dino.tw's Avatar
20% is okay. wanna more low end torque then choice more nitro.
dino.tw is offline   Reply With Quote
Old 08-09-2005, 12:26 PM   #3
I run 20% and could not be happier. Watch out the .28 has crazy power.
8man is offline   Reply With Quote
Old 08-09-2005, 02:12 PM   #4
If I go up to 25% would the extra nitro just be compensating for the extra room for combustion, being a slightly bigger engine, or would it actually give it extra power? If any of that makes sense!....lol
Old 08-09-2005, 11:40 PM   #5
Nitro Tech
dino.tw's Avatar
How many % nitro...it is just like how many compression bar to a turbo engine. There are two main fuels of your engine. One is methyl alcohol another is "AIR". Higher nitro % = more air
Old 08-20-2005, 12:15 AM   #6
ntloser's Avatar
Default 30%
I am using RACE 30%.
ntloser is offline   Reply With Quote
Old 08-20-2005, 11:57 AM   #7
And it runs ok with 30%, right? What temp plug do you use & have you modified the engine? Or does it run just fine with no modification with 30%?
Old 08-20-2005, 12:56 PM   #8
ntloser's Avatar
So far so good. I am still breaking it in. An excerpt from the manual indicates they have planned on people using %30
FUEL
Total thickness of head shim
Under 20% Nitro
0.3 mm
25% Nitro
0.4 mm (0.1 mm)
30% Nitro
0.5 mm (0.1 mm)
It appears that it is okay to run the 30%
EDIT I am using an OS 8.. but don't follow my example. This is only my 2nd engine and my first engine, the k 4.6 lost mad power on the start of the 3rd gallon.
wtb nitro engine shannonmcb R/C Items: Wanted to Buy 9 01-23-2006 10:52 PM
WTB 30 mm rear jaco nitro 5 star foam tires and .12 turbo 5 port nitro engine & pipe fasthpir40 R/C Items: For Sale/Trade 0 01-24-2005 09:03 AM
WTD....12 nitro engine 6Cuda6 R/C Items: Wanted to Buy 9 06-25-2004 02:49 AM
new to nitro, what kit? engine? poonstar Nitro On-Road 4 05-15-2003 04:38 PM
FOR SALE:Nitro 4tec, Hopped Nitro Rustler, Parts lot, Picco .12 engine, plus more!!!! feel my impact R/C Items: For Sale/Trade 0 08-05-2002 10:41 PM
