Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Run Out Of Fuel Before 5 Minutes - Novarossi 353 >
Old 04-12-2013 | 09:22 AM
  #16
Extra tip:
Throttle management. Roll onto throttle, try to do some technical sections of the track with partial throttle, realease throttle earlier prior to sharp corners.
In 1/8 top level, Collari makes 5mins and wins races while other stop at 3.5mins...
fulcrum2 is offline
Old 04-12-2013 | 05:11 PM
  #17
wingracer's Avatar
Originally Posted by afm
1/2 a second on total run....if you are making 4.30 minutes per tank you´ll make 5.o minutes.
for fuel saving it´s got to be non conical.
afm
That's half a minute, not half a second.
On another note, you said it was noticeably faster leaned out, so lean it out. Go faster and make time. Don't get too worked up over temps (within reason).
wingracer is offline
Old 04-12-2013 | 11:40 PM
  #18
hi bailey gets 5 minutes times at brendale even with modded rossi//353 flash did it with no problems we use 2660/conical 5 finn using kit gears/spurs/mtx5///QLD like most 16 year olds he drives flat out all the time
greg.dawn is offline
Old 04-15-2013 | 05:29 AM
  #19
El Nitro's Avatar
Ive had the engine in bits. Looks OK (first nitro car engine Ive had apart though). A couple of very experienced racers also had a look at it and thought it looked OK too.
One of the guys said its very likely my setup. (clutch, two speed, tuning) Hope he's right and ill get it sorted.
Thanks for the advise.
El Nitro is offline
Old 04-15-2013 | 05:31 AM
  #20
El Nitro's Avatar
afm
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
Thought that was what was being implied.
El Nitro is offline
Old 02-01-2014 | 02:08 AM
  #21
Ultra_Aussie's Avatar
El Nitro how did you end up going with this in the end?
Ultra_Aussie is offline
