OS .12TZ Suprise
Old 09-16-2012 | 03:32 PM
RacerX11's Avatar
Default OS .12TZ Suprise
Ok, I put in a brand new 3port piston and sleeve into my TZ which was originally a 5 port. I set all the carb settings back to factory. I fire it up to start the break in process, as soon as I fire it up and put it on the ground, it sounds and performs like its already broke in! Plenty of blue smoke coming out the pipe. I checked for leaks and didnt have any, even change the fuel line. I've never had this happen before. Has anyone have this happen before?
RacerX11 is offline
Old 09-17-2012 | 06:51 AM
g-wan's Avatar
same goes to me when im using tz spec 2 liner,but i feel worried at 1st but after breakin and bring to track for tuning the liner has alot of pinch so i got no problem with my tz
g-wan is offline
Old 09-17-2012 | 10:41 PM
RacerX11's Avatar
Good to hear. I just took it easy and just heat cycled the piston and sleeve and varied my throttle doing it. Also richened the hsn an hour and I am getting really good power and fuel economy and it idles really good.
RacerX11 is offline
