RB Concept Engines
RB Concept Engines
I'm about to get a RB WS7-II and looking at running 30% fuel in it. It says that you have to add shims to the head to run anything higher than 25%. Well I looked at purchasing some RB head shims and they have 2 types of shims: long-stroke and standard. I can't find any where that says if the engine uses long-stroke and standard. Also how many extra shims would I need and what size? Thanks in advance.
You could take a look at the exploded view ( http://www.rbproducts.com/explose/RB.../01004-WS7.pdf )
The part numbers for the head shims are there.
John
John
Why have you decided to use 30, not 25 to avoid having to use shims
The stock engine runs perfect on 30% without adding extra shims. The reason I don't use 25 is because LHS doesn't carry it; only nitro in increments of 10. I just run a little colder plug than usual. I love this engine once I got the right pipe. BTW don't use a Jammin JP-1 pipe on the WS7-2; it kills the bottom end power.
I'm running a Jammin JP-2 hard anodized pipe. Very sweet pipe. Works a hell of alot better than the JP-1.
glad I bought the jp2 tonight instead of the JP1. I am also running the WS7II and was debating on one or the other.
Need help with id of this engine:
Soposed to be, a .12 V12 Rody part #01700-000425
I'm just not sure. The crank doesn't look right. It looks more like the 01700-000445. I don't know if being built in late '03 makes it a 425 crank. I bought this used so I don't have the box. Any help you can give me will be great. Thanks.
Pic of crank:
Pic of crank:
is that rust in the first pic there?? on the crank an around the con rod??
turbo button for RB x12 #215
I have a non turbo RB x12 #215 engine. I am looking for the turbo button for it. Does anyone know where I can find one?
hmmm youre not using after run oil, are you? just a quick brush of dremel or sandpaper and then metal polish and its good as new.
JP-2 is good for WS7II and JP-1 for S7II (which I have)
