Old 04-24-2012, 06:05 PM   #1
Default Glow Plugs keep going out.
I bought 3 new LC4 plugs for my cars and my RS4 killed them all. I put the first one in, and after it didn't start for a while I checked the plug and it was dead. I grabbed a new one, checked it before putting it in. After the car failed to start, I checked the plug and it was dead also. 3rd one did the same, car never started.
Again this is on a RS4 with Nitro Star T3.0 engine.
Silo is offline   Reply With Quote
Old 04-24-2012, 06:34 PM   #2
Bubblehead's Avatar
What is the voltage of your glow plug ignitor? I would try an O.S. A6 or A8 with that engine the LC4 is for a T-Max engine.
http://www.osengines.com/accys/glowplugs.html
HPI recommends a cold plug.
http://www.hpieurope.com/piw.php?lang=en&partNo=15107
Bubblehead is offline   Reply With Quote
Old 04-24-2012, 06:42 PM   #3
I use a cable plug hocked up to a Duracell Procell 6v.
I've ran LC4s before as thats what my LHB carries. This is the my first time with this problem? Also, this isn't my first 6V, this a new one that I got.
Old 04-24-2012, 07:12 PM   #4
Bubblehead's Avatar
Glow plugs only require 1.5V, 6.0V could be burning up your glow plugs.
Old 04-24-2012, 07:52 PM   #5
I've been using a 6v for years, this is my 3rd battery, and this is the first this happened. Anyway I can use a reduced? I don't want to let this brand new 6v go to waste. I'm using a Hangar glow starter.
Old 04-24-2012, 08:00 PM   #6
Bubblehead's Avatar
Read - Final Thoughts #9
http://www.osengines.com/accys/choosing-glowplugs.html
Old 04-25-2012, 06:00 AM   #7
Default glo plugs
plug would glow that bright you coud burn hole in pistin//ha /ha or you could have worn engen that will blow plugs
greg
greg.dawn is offline   Reply With Quote
Old 04-25-2012, 08:00 AM   #8
scary_jerry's Avatar
Smile glow plug hates 6 volts!
Your 6 volt battery need not go to waste....that's a 'camping lantern battery'.
It will remain a plug killer until you wear the battery and your wallet down.....really, don't use 'lantern battery'.
scary_jerry is offline   Reply With Quote
Keep destroying glow plugs. Why? dusty trail Rookie Zone 11 04-02-2011 08:48 AM
burning through Glow Plugs skoalisbad4me Nitro Off-Road 14 03-20-2010 10:04 PM
Winter Weather/ Glow Plugs... TotalNOOB Monster Trucks 20 11-18-2009 08:49 AM
Nitro Diesel - no more glow plugs, double run times asw7576 Nitro On-Road 6 03-20-2008 03:20 PM
