Old 04-01-2012, 11:59 AM   #1
ugglasdav's Avatar
Default Replace parts or Buy New Engine
hi guys and gals, need some advice on what to do, i ran my engine way to hot and there is some serious pitting on top of the piston, in the center of the piston its fine but anywhere around that has alot of small pits, more being towards the exhaust port, the piston also has a deep scratch in the side towards the top, the head button or conical head also has a huge amount of pitting, both the piston and the head button have a huge amount of pitting and there surfaces are like sandpaper. this engine is not that old as it was due for its first new con rod, it has around 5 liters of fuel through it from new, the sleeve just has a few scratches on the inside, my question is should i replace the parts that are damaged hoping that the rest are ok or buy a completely new engine, the engine is a IDM RCW, the same as a picco torque, so parts would be cheap but i still dont know what to do. i am almost certain the damaged was caused by the engine operating at to high of a temperature, but could this happen in just one race day?, i cleaned out the engine about 2 weeks before the race day and it was fine
>Shepherd Velox V8/Team associated TC5R
>>IDM 2011/ Speed passion/Much More
>>>Sanwa m11x
ugglasdav is offline   Reply With Quote
Old 04-01-2012, 01:38 PM   #2
HHH
HHH's Avatar
I had a similar thing happen with a Nova, but my trouble came from using a higher nitro percentage. The advice I got was: change the button head and use a small amount of metal polish on the top (only the top) of the piston to polish out most of the pitting.
You also want to replace the conrod and may consider adding a .05mm or .1mm of head shims. I did this for my engine and it ran well, as fast or faster than before. Engine still runs and raced 5-7 liters after the pitting(detonation).
Not sure how big the scratch on the side is but if not too big should not be an issue.
HHH is offline   Reply With Quote
Old 04-01-2012, 01:49 PM   #3
ugglasdav's Avatar
Thanks HHH for the reply, for some reason i dont thing the pitting will come out of the piston, the pitting is really bad and the pits them selfs look quite deep into the piston, im running 0.30 mm head shims witch is the standard for the Torque, i am also using 25% fuel
>>>Sanwa m11x
Old 04-01-2012, 03:14 PM   #4
Grinder's Avatar
Feel the bearings with your finger. If they are smooth, then I would recommend a new piston/sleeve/rod/button. Make sure you have at least .50mm of head shims. That makes a head clearance of .50mm. I run .55mm of shims in my picco based engines. .12, and .21 engines.
The picco .21 engines including the idm come with .40mm of shims. That's too low for 25% nitro. It's too low for 20%. The stock clearance is ok for 16%.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 04-02-2012, 07:43 AM   #5
ugglasdav's Avatar
thanks for your input, tryed using a small amount of metal polish on the top of the piston, made it abit smoother but there is still those deep pits in it, really at this point it needs a new Rod/liner/piston/head button, the bearings are not the smoothest, but seem to be ok
>>>Sanwa m11x
Old 04-02-2012, 08:28 PM   #6
HHH
HHH's Avatar
New engine time!
Old 04-03-2012, 05:50 AM   #7
ugglasdav's Avatar
Originally Posted by HHH View Post
New engine time!
>>>Sanwa m11x
The New Werks B5 .21 Racing Engine Werks Offroad Nitro Engine Forum 9312 11-08-2017 11:45 AM
What really kills an engine shipwama Nitro Off-Road 44 01-10-2009 07:13 PM
Mid Budget Racer .12 (what to buy?) os or nova mrwilson Onroad Nitro Engine Zone 41 04-28-2007 01:38 PM
Buy New or Rebuild Existing Engine blanks596 Onroad Nitro Engine Zone 9 10-28-2006 07:39 PM
