Nitro on road fuel
Old 02-08-2012 | 12:34 PM
Default Nitro on road fuel
Hi guys,
What is the best nitro and oil percentage for 1:8 and 1:10 onroad engine?
elkapitan is offline
Old 02-09-2012 | 07:44 AM
Originally Posted by elkapitan
Hi guys,
it either performance or protection
kyosho malaysia is offline
Old 02-09-2012 | 10:02 AM
Can I use a 30% on a .12 and . 21 nitro onroad engine? Some said that 20% is the highest nitro percentage for an onroad engine. Don't have any idea sorry. Just planning on getting into onroad
Old 02-09-2012 | 01:35 PM
Flygio's Avatar
Engines are factory set for 25% for .21 and 16% for .12
Doesn't mean you can't do things different, but since you're not into fuel stuff...just don't !
I make my own fuel for on road use with 8% oil: 5% synt + 3% castor. But if you ask a thousand people you'll get two thousand different blends !
Without a solid experience I'd discourage you to make your own fuel. Just buy a bottle of a good brand fuel, and let your knowledge start from there.
ciao
Flygio is offline
Old 02-10-2012 | 08:39 AM
for the factory recommended, .12 using 16%,.21 using 25%. If you want to use 30% in your .12 engine,you need to add 0.3mm head shim.(0.1mm shim for 5% nitro increase)
Old 02-10-2012 | 06:17 PM
My experience is in 1/8 on-road racing. The most important aspect IMO is adequate lubrication at high RPM. I use fuel with 25% nitro and at least 10% oil (preferably castor : synthetic ratio 6:4). I am currently using Cosmo 25% Racing Star.
peppernick is offline
