Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
ENGINE VENTILATION - Body cutting >
Old 11-24-2011, 04:59 AM
Rubio's Avatar
Default ENGINE VENTILATION - Body cutting
I have new bodies for my V-One and I'm wondering which is the best solution to balance engine ventilation and aerodinamic.
I used to make a hole on the front glass in the middle-high position and to remove the front/side glasses and completely remove the rear glass.
Some advise needed...
Rubio is offline
Old 11-24-2011, 02:18 PM
nikoskar's Avatar
This is correct. I think that you'll also remove front left and right glass.
nikoskar is offline
Old 11-24-2011, 08:20 PM
rcabj's Avatar
yes..normally the front hole( for fueling purpose) and rear hole (for engine ventilation/cooling effect) , the front sides window (both sides) . but some says leave the front sides window for better aerodynamics.
rcabj is offline
Old 11-25-2011, 03:04 AM
Rubio's Avatar
Thanks for your suggestions.
My doubt is mainly relevant to rear glass, if to remove it completely or to just open a hole similar to the front glass one.
I've heard different opinions on that...
Rubio is offline
Old 11-29-2011, 09:07 PM
rcabj's Avatar
well if u remove the whole rear glass, for sure more ventilation/airflow that allows more cooling process to take place. if u remove smaller portion of the rear glass then less air flow . for me to be on the safe side i prefer a lot more air
rcabj is offline
