RC Nitro STR Lightning engine sputters when hitting second gear.
My redcat STR Lightning idles fine and runs great, But when I run fast it sputters when I hit second gear. I dont know what to do... Pls Help
If it was too rich (getting too much fuel) you would probably already know this and it might not even be able to get into second.
If you richen it and it seems to perform a little better but doesn't hit second, maybe this is why it was (if it is the case) struggling for power hitting 2nd. The 2nd gear is set too high and because of this, the engine is trying to rev way too high and the only way it could do it is by running too lean. Sure it might be able to reach a higher RPM, but it would take away some power as well and so it would find it hard to keep running in second.
That's what I think is happening.
