1/10th INS Box.
Old 06-30-2011 | 07:00 AM
jcrc's Avatar
Default 1/10th INS Box.
What are the advantages of using the INS Box, if it's not mandatory in your local track? On the order hand, what disadvantages will I get from using it? Thanks in advance for your responses..
jcrc is offline
Old 06-30-2011 | 07:18 AM
lil-bump's Avatar
INS box is only used for noise reduction. Some countries have a decibel level for nitro engines. The INS box helps meet these restrictions. As far as performance there is no performance gain. The engine will have to be re-tuned once you start using one. I believe it will restrict a little bit of air that enters the carb.
Pass you soon...
lil-bump is offline
Old 06-30-2011 | 09:18 AM
impalabob64's Avatar
Pass you soon...
Also helps with alittle with fuel mileage .
impalabob64 is offline
Old 06-30-2011 | 01:55 PM
GMartinez's Avatar
also will keep your filter slighlty cleaner
http://www.superiorhobbies.com/istar...d=XCE103008!SH
GMartinez is offline
