Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
NOVAROSSI FLASH .12 PT TUNED >
Old 03-23-2011 | 08:37 AM
FF25510's Avatar
Default NOVAROSSI FLASH .12 PT TUNED
HERE WE GO
FF25510 is offline
Old 03-23-2011 | 08:40 AM
FF25510's Avatar
part two
FF25510 is offline
Old 03-23-2011 | 08:45 AM
FF25510's Avatar
part three
FF25510 is offline
Old 03-23-2011 | 03:55 PM
Does the drilled holes constitute a nother port according to the rules
Also there is a big diffrence in quality to the machining to the casing alone well worth the money if you ask me
rufazz is offline
Old 03-23-2011 | 08:59 PM
Riketsu's Avatar
They are not transfer ports... Therefore does not violate any rule.
353s has two holes.
People call them "boost ports", but really, they are just there to cool down and lubricate the skirt of the piston...
Riketsu is offline
Old 07-01-2011 | 02:50 PM
Any reviews on this engine how does it run and is it a pain to tune.
What about weather change is it effected easily?
speed6 is offline
Old 07-03-2011 | 02:43 AM
FF25510's Avatar
i break in with WOT and then having over 3L running on track, to me, easy to tune and i can get 4m30+ mins and stil with good smoke
FF25510 is offline
Old 07-03-2011 | 02:57 AM
FF25510's Avatar
a little more about the engine i used.
ttl .4 mm head shim
rapicon 25% fuel
original plug
capricorn 2662 set
running temperature 120C to 135C
with this combination, engine running smooth with both good low and top end.
the most important to me, good fuel consumption.
FF25510 is offline
Old 07-03-2011 | 04:18 AM
Default Gasket interchangeability?
As you already know, the new 2011 Novarossi Flash PT (S) range of engines requires a different exhaust gasket when comparing with older 2010 Novarossi Flash engine range.
Can these be interchanged? Has anyone tried to use the older variant exhaust gasket on the 2011 Novarossi Flash PT (S) range of engines?
Happy Birthday America!!
mhavlena is offline
Old 07-03-2011 | 08:24 AM
FF25510's Avatar
i use the old NR type on my .12 and .21 engine, both fit.
FF25510 is offline
Old 07-03-2011 | 11:18 AM
nice!
RC PIT SHOP HK is offline
Old 07-04-2011 | 04:21 AM
Are they steel bearings in this engine?
mrgsr is offline
Old 07-04-2011 | 04:46 AM
tl2111's Avatar
Johnny
PT = rear ceramic
PTS = front and rear ceramic
tl2111 is offline
Old 07-04-2011 | 04:47 AM
FF25510's Avatar
they have two version
PT - front/steel rear/ceramics
PTS - front/ceramics rear/ceramics
other then that both the same.
FF25510 is offline
Old 07-06-2011 | 08:50 AM
Just wanted to know if anyone else has come across this recently. 2nd raceday on my novarossi .12 flash tuned motor and the rear bearing is completely shot luckily I didn't do any damage to the motor. Motor never got over 220 ran just fine the entire race just noticed after breaking the car down. I have heard of this happening recently but never came across it personally. Brad
bradley70 is offline
