Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
My Brand New Engine Is Locked Up!?!?! >
Old 08-30-2004 | 06:17 AM
Default My Brand New Engine Is Locked Up!?!?!
I bought a HPI .12R XS Non-Pull Start Slide Carb Engine and after putting it on my car and trying to start it with my Ofna Starter Box it locked up.
I looked at the engine and the Flywheel would not spin at all! I let some friends look at it and they took off the bottom peice of the engine to look inside and the the piston shaft is totally vertical.
How can I fix this? Does this happen a lot to other people? Will this problem eventually go away?
J Smith is offline
Old 08-30-2004 | 06:25 AM
fordman500's Avatar
Some motors are just super tight.Take a hair dryer or better yet a heat gun to get the head nice and warm.That should help.Also until you break it in you can use a flat head screwdriver to turn the fly wheel.
fordman500 is offline
