x-12 vs rrl3?
Old 08-24-2004 | 02:19 PM
  #31
Grinder's Avatar
The JP version of the X12 is better than stock, but no where near it's potential. The JP X12 sleeve is good, but the crankshaft is pretty plain. It has a turbo scoop and a couple of minor mods to the crankshaft, but there is absolutely no increase in timing. JP lightens the crank a little and puts a fuel ramp to fill the hole where the metal was removed. Yes, better but not best.
Grinder is offline
Old 08-25-2004 | 06:37 AM
  #32
jag's Avatar
jag
Uriah, are you getting good results modding the X12? Is that the fastest 3 port around now?
jag is offline
Old 08-25-2004 | 06:58 AM
  #33
Grinder's Avatar
From what I have seen it's very fast and last a long time. Some others are just as fast, but wear out faster (mcp). I guess we'll see next week at the nats, where I am sure there will be no shortage of fast motors.
Grinder is offline
Old 08-25-2004 | 07:22 AM
  #34
jag's Avatar
jag
Do you like it better than the RR L3 and the NSR? It will be interesting to see the results at the nats. I assume you are going. What engine will you be running?
jag is offline
Old 08-25-2004 | 10:47 AM
  #35
jag's Avatar
jag
When people say that the RR L3 is for shorter tracks how short do they mean? Would you consider Ft. Meyers a short or long track? I think I am racing on a short track but I don't have much to compare it with.
jag is offline
Old 08-26-2004 | 07:31 PM
  #36
got my x12 today well rodered it should be gettin it by tuesday $285 shipped lol
Bxclip is offline
Old 08-26-2004 | 08:01 PM
  #37
If the ts12 is the same as the ns12, and the ns12 is the same as the x12 , why buy the x12? Just curious.
The ts12 is only 219 at nitrohouse.
Johnnytc3 is offline
Old 08-27-2004 | 12:29 AM
  #38
Team-RTR's Avatar
the X12 IS faster, dont know why dont know how.
Team-RTR is offline
Old 08-27-2004 | 12:06 PM
  #39
frome evrone i asked htey said the x12 is the fastest and most reliable engien which beats turbos.. the ns12 is al il slower on top end and less rleiable
Bxclip is offline
Old 09-01-2004 | 11:16 PM
  #40
Default Needle settings on X12
What are the neddles setting on X12 for breakin in?
I opened the box and found out that the mid range needle was not flush, needle was way screwed in.
HSN was 5 turns out, LSN was 4 turns out.
are these settings suitable for break in? how about the idle speed?
if this engine exactly the same as NS3, why even bother to pay more money?? i also don't know why i pay more for this engine.
thanks for your help.
Icung is offline
