Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Need Help with Stuck Sleeve!!! >
Old 07-15-2004 | 05:28 PM
serpentsixty9's Avatar
Exclamation Need Help with Stuck Sleeve!!!
ok, i tried pulling the sleeve out of my rs12s2, but its stuck, i heated it up with my heat gun,and i got it out half way, but no more, and since i didn't want to use any more force, i thought there was something wrong. It just won't budge now, up or down, the piston moves freely up and down, but the sleeve is stickin halway outta the engine! The engine has about 13 tanks on it. My dad suggested i wait until the engine cools down to room temp to move it back down, then heat it up again from that temp,and pull it all the way out, i also can't twist it either. please help! heres a pic to help you.
serpentsixty9 is offline
Old 07-15-2004 | 07:13 PM
I had the same problem with my Picco last week. What I did was drop the piston down and then moved it over so that whenI turned the shaft, the piston hit the bottom edge of the sleeve and pushed it the rest of the way out. It's probably not the best thing to do to the piston, but it worked.
crackerjack is offline
Old 07-15-2004 | 09:44 PM
Ah10's Avatar
Default Re: Need Help with Stuck Sleeve!!!
Use a zip tie, a big one and slide the zip tie tip in the exhaust port and then push the piston up. the zip tie will stop the piston from going up that means it will push the whole sleeve upward. It works every time!
Ah10 is offline
Old 07-16-2004 | 01:14 AM
Ybakoff's Avatar
Have the same problem with my new motor, Have to give this a try.
Ybakoff is offline
Old 07-16-2004 | 05:28 AM
I tried the zip tie trick. The sleeve kept slicing it off.
Old 07-18-2004 | 10:59 PM
theRED5's Avatar
You need a BIG zip tie, one like you'd use as a tank pull.
theRED5 is offline
Old 07-19-2004 | 12:03 AM
Rapid Roy's Avatar
You can also use the handle of an old toothbrush to do the same thing as the ziptie
Rapid Roy is offline
Old 07-19-2004 | 03:27 AM
soc123_au's Avatar
The zip tie usually works, if it shears off you can use anything that fits through the exhaust port that is soft.
soc123_au is offline
Old 07-22-2004 | 12:37 PM
fraz's Avatar
Even zip ties can damage the edge of the really soft pistons we use nowdays. Since you got the sleeve that far out, find something you can set on the top edge of the engine case next to the sleeve to use as a fulcrum. Then get a wide blade screwdriver and lift it out from the bottom of the lip on the sleeve. I typically won't use the word "pry" but essentially that is what you will be doing. Just be smart about using the fulcrum and you will not damage anything.
The only time this hasn't worked for me was when I had sleeves that were cracked all the way around the transfer ports. Then you'll be lucky to get it out at all because the edges of the sleve dig into the inside of the case like fishing hook barbs.
fraz is offline
Old 07-25-2004 | 02:15 AM
Julius's Avatar
Use this trick in combination with heating the crankcase with a heatgun.
Julius is offline
Old 07-25-2004 | 07:26 PM
Preheat the oven to 270 degree and place your engine inside for 5 to 10 minutes. Take it out and you can easy to remove the sleeve. Pls don't put any salt ...
Raycer is offline
