TAIWAN Talk Thread
#76
Originally posted by jeffreylin
Do you think 6.95 is too tall for 1st gear? Thanks!
To me,I love smaller 1st ratio and 2nd ratio. For the smaller 1st,I can open the throttle before apex and my car will not too sensitive. And I usual setup the 2-speed system very easy to jump. When I full throttle the 2-speed system should jump soon. You have to control the throttle also 2-speed system yourself. When it should start 2nd gear you can control by your finger,not just wait the car's speed up. So my car is "MT" but yours is "AT",who faster? It is good when you need ballistic sprint. But you need to adapt it.
There are only two corners I have to full close the throttle in silverstone. The other corners I usual half-close the throttle then full throttle to pass the apex. Of course that is 1/8 running style,but I believe a well setting 1/10 can do so,too. So I will not use bigger than 7.0:1 ratio at that track. Sometime you feel it punchy but it dosen't mean your car has speed.
#77
By the way,I'm a long-winded guy. Sometime you ask me one question about R/C but I will give you ten answers. Maybe those answers even do not concern to your question. It usual happen to me. I'm sorry,buddy.
#78
Dino, I appreciate your thoughtful answer to my question.
By the way, taller=smaller FDR number. For example, a FDR of 6.95 is taller than 7.28. On the other hand, 7.28 is shorter than 6.95.
Coming from racing electric, gear ratio is one of the most important tuning parameters. With a high bite track, you generally want to gear as tall as possible since you can keep the corner speed. However, you do risk burning your motor if you gear too tall. I don't know if and how this applies to nitro engines. They seems to have so much power I shouldn't have to worry about overgearing? or should I? This is why I asked the question.
Yes, the lap time will tell what works better, but there is so many other varibles from one run to the next (tire size, temperature, traction) I can't be certain if it's this or that.
I will have to try to keep my hand on the throttle more. But this car rolls so darn free that I feel it will never slow down in time to make the turn unless I apply brake.
#79
We have to record the wearing speed to any track. Sometime it is 1mm/10mins or so. Before the final start,we have to choice the right size of tyres and suitable drive high. You have to know what size tyre that your car is the easiest to drive. Big tyre has better grip but small tyre more easy to control. Also you have to know the overdrive change ratio to your front & rear tyres. The rear tyres usual wear more fast. So this parameter is also very important to long time final.
Then the grip change condition to this track. The surface temperature more high the grip more less. And the track usual has less grip on the morning. So use softer tyres on morning and noon but harder tyre on evening. Some track has huge different grip on morning and evening. That is what expert care about first if he first time be the track.
With the right tyres you are 80% to the way.
#80
#81
i'd go for the 7.29/5.0 if your engine can rev up.
u need alot of acceleration in the infield...just make sure there's no time gap in your 1st/2nd shifting. Also make sure you have enough speed in the straightaway and power brake.
#82
#85
Hi Dino,
Excuse me for this beginner question.
When you guys say taller, are you referring to the pinion gear being smaller or bigger or is it the spur gear being smaller or bigger?
Thanks.
Thanks.
Originally posted by dino.tw
To the nitro car it just opposite to EP. If your 2nd gear is too short,your engine may be burnt when your tyres are too small. It usual happen on Japanese kits or Taiwanese kits. When your engine over-rev,it is a serious damage to any moving part. Most stock gear is design for brand new tyres. The new tyre diameter is about 64mm or so. But when you use less than 60mm tyres your engine will work mare hard. So it also concern to foam-tyre characteristic is different to rubber tyre.
#86
Originally posted by f2000racer
Hi Dino,
Thanks.
Hi Dino,
Thanks.
#88
if your car spins out when your wheels are going straight...there should be a problem with it,
when braking with one-way you actually tap the brake instead of holding the brake
#89
If you play at Lunging or Dashi,you do need 7.29 1st to get a lot of acceleration in the infield. But if this sunday Jeffery join the silverstone cup,you still suggest the same idea at such a width open track?
