TAIWAN Talk Thread
#301
Originally posted by cyba888
Dino,
For the top 3 drivers in 1/10th do you know what bodies were used?
Dino,
2nd: ProtoForm Mazda6
3rd: Titan Mazda6
#302
Originally posted by kitracer
ah 10, u jump, I jump
#303
Is this the track that 1/8 traction roll?
#304
Originally posted by dino.tw
Don't forget to install a high quality digital servo ... j/k
#305
It's on!
Hey Derek, are you ready?
#306
Re: It's on!
#307
Re: Re: It's on!
Bring it on! Will you be bringing it back to Taiwan? Any plans on coming here soon?
#308
Still havent raced yet....but I will once you get here. I need Dino to tune my engine When I let go of the throttle it doesnt return back to normal rpm quickly. Also been busy and out of town, but hopefully will do some track time soon before you get back. Dino I know your reading this, I need your help with my clutch as well.
#309
Oops I forgot to relpy you...
We have a race meeting at Da Shi this weekend. AKO and I will go there for practice those two days. So...next week ok?
#310
Derek,
Derek,
#311
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
i know there are a couple of problem causes this effect.... can somebody GURU out there list down...
thanks.
mop
#312
Originally posted by mop_iko
what caused this?
thanks.
mop
what caused this?
thanks.
mop
Too many possible.... let me think....
1)Idle open too much or/and low speed needle too rich;
If the singing is from high to low that means your engine has too much air flow when you close throttle. Close the idle till engine die out then open it a bit. If she is easy to die out,lean the low speed needle for compensation.
2)low speed needle too lean or longer pressure line too long;
If the singing is from low to high that means your engine has not enough fuel when you close throttle. Rich the low speed needle or shorten the pressure line.
3)Engine overheat;
When carburetor is very hot some fuel will be used up on cooling. It is the same as #2.
4)Air leaking;
When there is any air leaking,the A/F ratio become abnormal.
5)Compression too high;
Too high compression also cause engine singing.
6).....Too many possible....
#313
That is what we say "Engine Singing",You need to give her one microphone. lol
at least we know 5, emmm let say 6 of them now!!!!
thanks!!!!
ok.. cyba888.... now you know WHICH problem need to focus... try your best to make your engine NOT TO SING too long.... no need to wait for dino.... go racing....
thanks dino!
mop
#314
thanks!!!!
thanks dino!
mop
thanks!!!!
thanks dino!
mop
#315
Who knows where to buy parts for electronic guitar on-line?
I need some parts to rebuild my very old e.guitar.
TambokGT,are you there?
