Engine Rebuild
Old 06-01-2004 | 04:22 PM
Default Engine Rebuild
Hi Guys,
I have 2 engines which I think need a rebuild as they have hardly any compression left, and can't idle well. The two engines are NovaRossi MR12 and the NovaRossi NSR5. What parts do I need in order to rebuilt the engine? Are the piston and liner and sleeve the same throughout the Novarossi range?
Sami
ttektek is offline
Old 06-01-2004 | 06:05 PM
EdwardN's Avatar
Default Re: Engine Rebuild
Originally posted by ttektek
Hi Guys,
Sami
I am sure you are going to need replace piston, sleeve, conrod, ( c-clips). Can't tell you if bearings are OK, but most likely if it is original P/S sets in there, might not need to chnge the bearings.
All MR, NS, RS, NSR are the same dementons for p/s sets ( short rod version), MT12 and old Top are log conrod version.
So in your particular case ( MR12 and NS12S5) you can use similar P/S sets ( 3 port or 5 port version-depend if you running ROAR or outlaw.)
EdwardN is offline
