opinion on nova ll3
Old 02-23-2010 | 07:21 AM
Default opinion on nova ll3
i got this motor from a great guy off this web site and im having trouble getting a tune just when i think its good it turns to crap the front bearing is leaking a little could that be causing all the problems its like it goes lean no matter how much i ritchen it up ive actually had the lsn screwed 5 turns out and it still acted lean the factory setting is 2.5 turns out ????
Please any help would be apperciated
Roadrash730 is offline
Old 02-23-2010 | 09:18 AM
Sounds like a air leak. Check all the seals and make sure the carb is seated all the way in the block. If those are good then its probably the front bearing leaking.
Joe Maxey is offline
Old 02-23-2010 | 09:43 AM
hey joe the front bearing is definately leakin i checked it just now the carb is all sealed up and set in all the way do u think u could check it out on sat at the track and tell me what u think?
Old 02-23-2010 | 09:58 AM
Sure we can take a look. You can order ceramic bearing from Boca for cheap. Walter at the track has the tool to put it in for ya. I think its bocabearing .com.
Just order a new one. I think there around 20 each.
Old 02-23-2010 | 11:07 AM
staikosn1's Avatar
You get what you pay...
I think TKO is the way to go!!
staikosn1 is offline
Old 02-23-2010 | 01:34 PM
What is TKO?
Old 02-23-2010 | 01:38 PM
Originally Posted by Joe Maxey
What is TKO?
TKO is another bearing brand.
Scott Fisher is offline
Old 02-23-2010 | 02:02 PM
problem resolved money refunded and motor returned thanks for the input but what i would have cost to fix it was well more that the actual cost. as i got into the motor there was more probs than i thought just an honest mistake so thanks to NOT dealing with a scammer it was resolved with no problems
