Old 02-14-2010, 01:03 PM   #1
Default JL evo3 TUNED
hey guys i need the factory settings for the jl evo3 tuned please no guesses i need the actual factory settings
thanks in advance
Dustin
Capricorn LAB C-01 / RBtj 10 / Spectrum DX3
Roadrash730 is offline   Reply With Quote
Old 02-14-2010, 01:38 PM   #2
Trader Rating: 62 (100%+)
Default jlr evo3 .12
thanks in advance
Dustin
Dustin ,I have a nib picco/jlr evo 3 .My specs are 6.25 turns out on lo speed from all the way in & 5.25 turns out on the high speed from all the way in .Hope this helps
martind1318 is offline   Reply With Quote
Old 02-14-2010, 06:20 PM   #3
Thanks so much maybe i can get this thing tuned right finally
Old 03-15-2010, 06:40 AM   #4
chromie's Avatar
would those settings be the same for the non tuned?
chromie is offline   Reply With Quote
Old 03-15-2010, 11:02 AM   #5
the setting posted r for the non tuned version i used them on my tuned and they were very close to optimal setting just had to lean it out on the hsn about 3 to 6 hrs and the lsn was just right but im also in central texas weather here is in the mid 70's the motor temped at 256 after a 5min run at the track on sat and the glopulg read just a bit rich right were i like it but anywas those settings will get u very close
Old 03-15-2010, 11:09 AM   #6
Chromie as per the other question about shimming u should be able to lean it abit more if your running 20% that motor really runs good around 260* I try to keep mine right around 255 or so and the plug allways reads good i use os rp6 plugs
Old 03-15-2010, 12:58 PM   #7
chromie's Avatar
Ah okay then, never knew they could run at those temps . so just leave the shim as is too?
Picco P9 EVO3 .21 Race Engine nigelnuggets Onroad Nitro Engine Zone 130 03-11-2015 09:02 AM
JL EVO 3 "TUNED" Team Kamikaze Onroad Nitro Engine Zone 396 07-01-2014 10:03 PM
JL Racing .12 nitrodude Onroad Nitro Engine Zone 2083 05-16-2012 02:21 PM
**PICCO JL EVO3 .12 TUNED BRAND NEW** aussies1129 Australia For Sale/Trade 38 11-17-2009 09:51 PM
