Ninja MRT .12 need help
Old 12-06-2009 | 09:00 PM
Kanea6's Avatar
Unhappy Ninja MRT .12 need help
Ive just put a brand new Ninja MRT in my car. Ive idled, it put on the track and now ive just started to put some tune into it. The engine just wont idle, it will idle then go to high revs an then die, ive got the idle right, when it idles its perfect but then when i take the glow warmer off it will be fine for about 10sec then go to high revs an die.
ive looked at the cd-rom that comes with it an it told me to check the exhaust, air filter, fuel lines, an glow plug ive replaced all that and its still doing it, iam thinking that its maybe loading up but that wouldnt explain why it revs really high at the end
Please help me
Kanea6 is offline
Old 12-07-2009 | 05:12 AM
jameslow's Avatar
- check the glow plug u using, is it hot enough for the engine to hold the idle?
- check if ur idle hole opening too small and low end too lean?
- u might want to try open up the idle hole slightly bigger and rich abit more on the low end!
jameslow is offline
Old 12-07-2009 | 05:51 AM
Default Glow Plug
I also own one of these motors, the non-tuned version. I have found that the best way to get a proper tune is to either have a Ninja glow plug or a novarossi glow plug. I have tried the O.S. plugs and I went through them like it was my job, but once I put in a nova plug the engine was easy to tune and reliable.
Hope this helps,
Carlos Marcano
werun is offline
Old 12-07-2009 | 07:06 AM
jameslow's Avatar
i use IDM plug on my ninja. Therefore i think u can try plug from idm,picco and sirio!
jameslow is offline
Old 12-07-2009 | 03:52 PM
Kanea6's Avatar
Ive got a novarossi plug in it, its #7, ill try an richen it a bit more an ill see how it reacts to it
thanks
Kanea6 is offline
Old 12-09-2009 | 04:52 PM
PROVK's Avatar
thanks
Nova plugs leak in GRP engines, I thought you would of known that being
a GRP dealer
PROVK is offline
Old 12-10-2009 | 02:14 AM
Kanea6's Avatar
Thumbs up
a GRP dealer
yer i do know that but its not a GRP motor, its a Ninja, ive compared the thread patten between the ninja plug and nova plug an they are the same, its all fixed now anyway it was too lean, ive richen the bottom end about half a turn an its a weapon now
Kanea6 is offline
Old 12-10-2009 | 02:40 AM
jca2000au's Avatar
Good on u young kane, let see how fast will you b on 20th.
jca2000au is offline
Old 12-10-2009 | 06:53 AM
Riketsu's Avatar
Since when Ninja and GRP are different engines? I thought GRP was a re-branded Ninja engine.
If a GRP plug doesn't leak in a Novarossi underhead does that mean a Novarossi plug will not leak in a GRP underhead???
Riketsu is offline
Old 12-10-2009 | 10:15 AM
musti72's Avatar
No, it doesnt mean like that. Nova plugs only fit on Nova engines. Most of the other plugs can also fit on Nova engines.
musti72 is offline
Old 12-16-2009 | 03:35 AM
FULLYSICKRACING's Avatar
One thing you should also try is checking your exhaust gaskets, i have an xray nt1 with an o.s 12tz and when the exhaust gasket is stuffed the engine wont idle properly.
FULLYSICKRACING is offline
