RD/Richey Racing Engine
#751
was gone 2 weeks. no new information to present. no new questions. working in the shop to improve the engine.
also been working on the last of the car issues with TM. On the positive side I have eclipsed the .90 HP mark with an R3 on our dyno but it requires extensive rework. Stock they are .74 hope to get this into production in a couple months. Also working on some quality issues. (this has been real tough)
Row
once the engine is warmed up and Idling turn the low speed needle in until the engine rpm rises. once it begins to rise back the needle out until the speed falls back (about a quarter turn) this will get you close once the high speed is adjusted and the engine is around 240 on 2 consistant tanks. readjust the low speed again.
Row
#753
thank you for the quick response. i know this is a good engine, i just don't know how to tune it and get the most out of it.
#754
Registered User
So I guess nothing special with the engine at the Nats?? Just wondering how it performed. Bob
#755
Hi Dennis,
Just to throw something out there for you to clarify. It is understrood that STS is the contracted mfg for the R3. It is also known that STS mfg engines to sell under its own name and also to another popular 3-lettered brand.
With this information, someone may say that the R3, the STS D3R, and the other 3 lettered motor are all the same. Now of course that is not true but my question to you is, how is the R3 different from the other engines from STS? Without going into the exact details of your design, what are some of the special features you designed in the R3 that we can expect as opposed to the other STS engines?
#756
The carburetor internally is a little different in the midrange area
The crankshaft is black coated and the timing was increased. I believe the d3 has gone to this timing. we asked for a different specification on the sleeve taper and piston fit. I believe the d3 has gone to this now also. The rod was changed. The cooling finset is obviously different. and that was the major changes for initial production. I am going to submit a new package to them soon which is radically different. right now if you take a d3 apart and lay it alongside a d3 they look the same to the naked eye. they are not that far apart. I have some durability improvments that we are working on also. The power out of the gate is ok a little better than an os tr but we want x12 level power and reliability. The package is done to get that level we just need to pull it together in the next production run which is a couple months off. It takes time to batch new parts and build them. i would expect the d3 to follow suit.
we needed to insure the reliability was there before we turn up the heat on the power and we have had some teething pains but if you know me I don't give up easily. If we can't get there we will look at other options.
#757
Dennis, I need more informations.....
#759
dennis
hey dennis what gearing did use at the winternats.
#761
Dennis?
Did you send me some momo?
#763
