RD/Richey Racing Engine
Old 11-23-2004 | 08:56 PM
  #646
glitch44's Avatar
Originally posted by mckrooz
Ok, I received the motor. Everything looks good. Just need to break in.
Mckrooz,
Please keep us posted. Very interested to hear the results.
glitch44 is offline
Old 11-24-2004 | 12:39 AM
  #647
Z00M's Avatar
Originally posted by Motorman
Zoom
sorry I've only been able to get in here about once a week right now. I don't understand the needle thing but did you perhaps change the plug at the same time?? (turbo plugs are prone to developing black death, if the end of the wire where its welded to the outer housing goes black the plug is toast. It only needs to go black about 2mm in from the edge, if this happens the motor will run rich and never tune) In my instructions I tell users to scrap the plug after you break the engine in. Did you change the head clearance?? How much nitro?? You need to get the engine into the 250/260 range in F for temp. the performance difference between 210 and 250 is huge.
Hey Dennis, no worries about the slow reply, I'm sure you're busy.
I changed the head clearance and also the plug before resorting to the needle change. I ended up with just the copper shim running 16% nitro. I also did the pipe mods you suggested.
I know what you mean about the needle as I don't really know why it fixed it. It was as though the needle supplied just couldn't seat properly and close the fuel flow. I will endeavour to change the needle back to the original and see if it returns to it's previous behaviour of being seriously fueled up at wide open throttle. Or I'll just be smart and put the micrometer on both needles and see if there is a difference. If there is, I'll get you to PM me an address and I'll send the needle back to ya.
If I saw that sort of performance at 210F, I can't wait to set it to run 250F if there is a huge performance difference
Cheers,
Mike.
Z00M is offline
Old 11-24-2004 | 01:33 PM
  #648
Motorman's Avatar
yea let me know what goes. if the problem follows the needle I surely want to see it.
You are running the short header on your car? The head clerance , yes it needs to be around .014 total head clearance on 16%. And yess the high speed needle will be quite deep in the bore when the mixture is right.
It also could still be the motor needed to free up more but usually that creates excessive heat so thats unlikley.
Motorman is offline
Old 11-24-2004 | 01:44 PM
  #649
Default DENNIS
hey dennis ,waz-up ,how the weather?
isuzuguy is offline
Old 11-24-2004 | 04:22 PM
  #650
Motorman's Avatar
COLD!
Motorman is offline
Old 11-26-2004 | 09:53 AM
  #651
YBSLOW's Avatar
COLD!
No way! I was just outside and it is about 75.
YBSLOW is offline
Old 11-27-2004 | 10:32 PM
  #652
tunerjetta29's Avatar
I just ran my RD Richey engine for the first time today at revelation for the 2 hrs it wasnt raining. Its quick and im still running it pretty rich in the 195-200F range. I cant wait to get it really tuned in and get my clutch and 2-speed adjusted right!! Great engine guys, and GREAT PRICE!!!!
tunerjetta29 is offline
Old 11-28-2004 | 09:08 PM
  #653
wad's Avatar
wad
What car were you running??
wad is offline
Old 11-28-2004 | 09:29 PM
  #654
HarKonnenD's Avatar
How did it run compared to other engines? My friend says this engine will blow the doors off an NS12 and Sirio Evo 2 5 port.
HarKonnenD is offline
Old 11-29-2004 | 12:14 AM
  #655
Z00M's Avatar
Default Needles
Dennis,
The Richey needle measured 18.6mm in total length and the STS needle was 18.0mm total length.
I spoke with the distributor for these engines over here and he hasn't had any other complaints from others having the same issue I had. Maybe it's just a one off.
I guess I'll just stick with the STS needle.
Z00M is offline
Old 11-29-2004 | 06:36 PM
  #656
Motorman's Avatar
Zoom its got to be a fluke. If theres something you need or want me to do let me know. can replace the part no problem. I will certainly cover the needle assy and the shipping.
Cheers
D
Initial sales of the engine seem to be going well thanks for everyones support. The RD Richey Mongoose R3 turbo II package seems to be capable of running at the front right out of the box. We are very happy.
D
Toffelmire that mild weather is why your growing a third eye LOL By the way I'll call you from FT Myers just to tell you how much fun Leo and I are having
Motorman is offline
Old 11-29-2004 | 06:48 PM
  #657
Dennis,
Are you going to be at Ft Myers before the Winternats....if so let me know....heard the new asphalt is smoooooth. Check your damn PM too......
later
G
peakman is offline
Old 11-30-2004 | 05:57 AM
  #658
YBSLOW's Avatar
Toffelmire that mild weather is why your growing a third eye LOL By the way I'll call you from FT Myers just to tell you how much fun Leo and I are having [/B][/QUOTE]
UUUUUUUUUUUUURGGH! Damn it! New jobs suck!
YBSLOW is offline
Old 11-30-2004 | 07:18 PM
  #659
bcquick's Avatar
Zoom i have a problem like yours my needle when bottomed out does not seat properly and does not shut off the fuel but my engine run fine about 1/ 8 from bottomed out so i guess its ok and a little better then your
but i did check a nr carb and they do seat completely and shut off the fuel maybe i will try an ns carb and see if run better then it already does.
for all those who want to know motor runs great everywhere just a little lacking in top end compared to a nsr , but for $180.00 compered to $280 it well worth the small differance on top,
if not on a very large track this motor can compete with any of them, very good motor!!!
bcquick is offline
Old 12-01-2004 | 01:11 PM
  #660
Motorman's Avatar
guys I am looking ointo this needle thing it appars there might be a tolerance issue that has popped up I will get to the bottom of it.
Peakman I will be at the winternats.
Motorman is offline
