Help with Mega MF 12
I need a PDF file showing an exploded view of the Mega Mf engine showing parts with part numbers, problem is not sure what version of Mega engine I have,the only info I can find is at MRC Planet.com they list 4 versions, 221003 Masmo ceramic, 221004 Masmo ceramic power-pack,
221005 Masmo ceramic IFMAR, 221006 cermic power-pack IFMAR
I can’t find none of above numbers on my engine. The only info I can see is on the side of the engine .12 MF by Novarossi, markings engraved by hand on the side of the engine mount 44-5-C
numbers stamped on the underside of engine mount 1145 06
I am led to believe this engine is now discontinued, so now concerned about obtaining spares. I have been told that Novrossi parts will fit but what engine would it be compatible with.
Any help would be very much appreciated
I just bought a Mega 12 MF (I had questions before I bought it on another thread) All the info on Mega engines can be found on the serpent web site but for some very strange reason is not there anymore?
I wanted to provide you with the link here.
If I do a google search ( Mega MF12 3P MasMo #221001 ) which is the engine I just bought it shows up! but I can't see all the other engines I seen just a few days ago
Try doing the same search if you are able to see it they have many pics and exploded views with part numbers
Hope this helps
I wanted to provide you with the link here.If I do a google search ( Mega MF12 3P MasMo #221001 ) which is the engine I just bought it shows up! but I can't see all the other engines I seen just a few days ago
Hope this helps
