Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Help with Trinity Picco .12RE >
Old 08-10-2009 | 04:20 PM
Default Help with Trinity Picco .12RE
I have a Trinity Picco .12RE that I am running in an NT1 with a Max power 2649 pipe. It only seems happy when it is running temps > 270F. The problem is that if it stalls I cannot restart it. It will not draw fuel. After 10 - 15 minutes cooling it fires right up.
I am using Byron's 30%(which everyone else is using). I did put the extra shim in the head. I have sealed the carb for air leaks. There is a small leak at the front bearing (just air when I pressurize it, not fuel when it is running).
This is my first nitro engine so I have no clue. It has stumped the local guru. I am just trying to make it through the last few racing days of the season and will replace it next spring.
Any thoughts or suggestions would be appreciated.
Regards,
Carter
darcydawg is offline
Old 08-10-2009 | 07:17 PM
impalabob64's Avatar
Default Ok
Regards,
Carter
Here is you first problem you running the wrong pipe an header,you need the pipe an header for Piccos you also can run the Sirio pipe an header also.The pipe # for the Piccos is 2607 an for Sirio 2611.Now what gearing are you running,how is your clutch setup.Hope this helps .Also Piccos like to run alittle rich on the bottom.
impalabob64 is offline
Old 08-10-2009 | 07:50 PM
I've had a nagging feeling I had the wrong pipe and header. For gearing I am using the kit set up which is 16/59 1st, 21/54 2nd. For the clutch I have yellow shoe, kit spring, 0.6mm gap.
For the pipe, would the 2651 work?
Thanks for the reply.
Carter
Old 08-10-2009 | 11:15 PM
NitroWD's Avatar
Carter
2651 is the latest pipe for picco engines, should be a better match.
NitroWD is offline
Old 08-11-2009 | 12:37 PM
Default Gearing
Carter
Go up 1 on you spurs 16/60 1st for 2nd 22/54 hope this helps.Yes 2651 will work .
Old 08-11-2009 | 02:18 PM
Ordered the pipe today. I will let you know how it works.
Thank you,
Carter
Old 08-17-2009 | 04:47 PM
I got the 2651 pipe today. It seems to make a big difference. The engine seems to be running 40 F cooler with the same power. Can't wait for Sunday to get it on the track and see how it tunes for a race.
Thanks for your help.
Carter
