picco parts
Guys can anyone tell me where to get parts for the jlr evo 3 red dot in the states.
You can give Nitrohouse or Kamikaze a check, you would be able to get all that you need.
Originally Posted by Ballistik Mods
(Post 7318228)
Originally Posted by jelayne
(Post 7320852)
Originally Posted by DK9mm
(Post 7317795)
I bought a new motoer from a fellow member. I am running 20% fuel. The motor came with 4 shims in three different guages. Should I remove the thinnist one if running 20%? I recall reading that these engines are set up for 30% from the factory.
Any help would be appreciated. Thanks. Shawn. |
thanks
Thanks heaps guys for the picco parts info:nod:
[IMG][/IMG]
(Post 7317795)
I bought a new motor from a fellow member. I am running 20% fuel. The motor came with 4 shims in three different guages. Should I remove the thinnist one if running 20%? I recall reading that these engines are set up for 30% from the factory.
Any help would be appreciated. Thanks. The other three seem to be the same........ Here is what I have.. Which one is this.... http://i744.photobucket.com/albums/x...9/IMG_0269.jpg |
Originally Posted by Shawn68z
(Post 7324017)
Yes. Take .10mm out the head clearance. It if its not the Tuned version then .40mm should be right for 20%.
Shawn. |
(Post 7324586)
[IMG][/IMG]
I take it the .10mm is the really thin one? The other three seem to be the same........ Here is what I have.. Which one is this.... http://i744.photobucket.com/albums/x...9/IMG_0269.jpg |
Originally Posted by dicksmth_2007
(Post 7324591)
what about for 16%
Same. 16% to 20% doesnt make much of a difference. Shawn. |
how does this engine compare to the Picco P1-R evo3 engines?
(Post 7324586)
[IMG][/IMG]
it may be the first version of the red dot
The top view of the heat sink looks like the 1st version (EVO 2), without seeing the end view of the Crank (Shape of the Scallop), can not be completly sure though.
| All times are GMT -7. It is currently 09:10 PM. |
