Engine Mods
Old 02-06-2004, 10:28 AM
  #136
EdwardN's Avatar
Originally posted by afm
In general terms, what performance change do you enhance if you increase induction by advancing opening or retarding closing of the crank opening.
I.E. advancing opening = more torque
retarding closing = more top end
Or is it the opposite.
Same way with transfer ports, what effect does it have to rise the port or lower it.
AFM
It is about right, but you have to remember of resonble limits and balance-meaningif you keep opening to any of the way try to achive one of the parameters and cross the limit line-engine will just stop perform at all.
Transfer port has to be at certain opening, to have enoough time to transfer all mixture to combustion chamber. Exhaust opening is more complecated. lower exhasut-longer dwelf time-more torq, higher exhaust-smaller dwelf time, less torq, bu higher RPM. Also difference between exhaust and transfer will dictate your pipe performance. There were alot of studies done to find the best suitble difference and so far is about 40 degree. In our aplication little bit different due to our pipe design ( two cycle).
\ Got go, will be later.
Didn't finish.
EdwardN is offline
Old 02-06-2004, 10:34 AM
  #137
Chewdogg's Avatar
I got question. Don't touch botom of ther port-it changes nothing. If you want to change timing just cut the top line of sleeve.
thanks TG
Chewdogg is offline
Old 02-06-2004, 12:46 PM
  #138
afm
afm's Avatar
Originally posted by Top Gun 777
It is about right, but you have to remember of resonable limits and balance, meaning if you keep opening to any of the ways trying to achive one of the parameters and cross the limit line.........engine will just stop to perform at all.
Transfer ports have to be at certain opening, to have enough time to transfer all mixture to combustion chamber.
Exhaust opening is more complicated.
-Lower exhasut-longer dwel time-more torq,
-Higher exhaust-smaller dwel time, less torq, but higher RPM.
Also difference between exhaust and transfer will dictate your pipe performance. There were a lot of studies done to find the best suitable difference and so far it is about 40 degrees.
In our aplication a little bit different due to our pipe design ( two cycle).
\ Got to go, will be late.
Didn't finish.
Thanks TG, think you have a plane to catch...we'll keep this interesting class for some other time....good luck...
AFM
afm is offline
Old 02-06-2004, 01:08 PM
  #139
rskoncepts's Avatar
Trader Rating: 37 (100%+)
I do very steep taper there, right under the exhaust port. It is free up piston. Under the exhaust port we don't need any sealing, so the more we take out-less friction we have there. It is only guyding piston to go straight. Sorry can't release phisical numbers-this is one of the numbers can be disclose.
You need to try, lap it little by little and will see the difference, once you got overlaped-you will notice the piston will hit top line of exhaust port on sleeve. When you got to that point, just mesure it and do little bit less.
Top Gun 777...can you explain that a little more. I taper the bottom of the exhaust port but not sure if you mean the same. Do you have pictures or drawing to illustrate that? Thanks
rskoncepts is offline
Old 02-06-2004, 01:18 PM
  #140
EdwardN's Avatar
In my post I was meaning to make bigger taper in diameter of sleeve, not the exhaust port it self.
i don't have saner to make pics of drawing, but will try find one, after winter nats.
EdwardN is offline
Old 02-06-2004, 01:26 PM
  #141
rskoncepts's Avatar
So you mean inside the sleeve so there is slight gap between the piston and the sleeve below the exhaust port?
Old 02-15-2004, 08:40 AM
  #142
Chewdogg's Avatar
If also you will use my P/S/conrod set you will see even a lot of more difference.
Hey TG do I buy the P/S/conrod set directly from you. I want to try one in my MR12(3 port) or my NS12 (5 port). PM me
later
Chewdogg is offline
Old 02-15-2004, 09:21 PM
  #143
EdwardN's Avatar
Yes you are right. On my P/S sets I have realy big tapering below exhaust port.
My P/S sets were use in Ft. Myers and you can check with Stefan abiout performance, he was the one of the racers who used. He loved it so much and reserved more from me.
EdwardN is offline
Old 02-15-2004, 09:23 PM
  #144
EdwardN's Avatar
later
Yeh, you can order from me directly. I expectin to have batch comming soon. Not too many left, but I still have some.
EdwardN is offline
Old 02-15-2004, 09:33 PM
  #145
Slotmachine's Avatar
Default EDDIE!!!!!!!
Where are you??????????????????
Slotmachine is offline
Old 02-20-2004, 07:10 AM
  #146
Chewdogg's Avatar
Hey guys,
I'm looking at the package of my mugen P/S set for my MR12. The package says MR RS NS RR...If these engines use the same sleeve what makes the power different?..Is is carb? crank?
Chewdogg is offline
Old 02-20-2004, 07:38 AM
  #147
afm
afm's Avatar
Hey guys,
What they are telling you is that it "fits" any of those Nova based engines, but it has probably Mugen's port timings, so in effect if you put that sleeve into lets say a RS you are timing it under Mugen's layout, but we still have the issue of crank induction timing which could be different from engine to engine.
I had an experience rebuilding an RBX12 with a Novamega P/S set and tried it with RB's crank and the engine had more torque, when I tried it with the Novamega crank, the engine had more top end
AFM
afm is offline
Old 02-22-2004, 05:40 PM
  #148
what are some good numbers for a 4 port .21 to achieve max lowend?
Josh K. is offline
Old 02-22-2004, 10:12 PM
  #149
this is my first time playing with timing and below is the numbers from the pos 4 port HPI .21BB I'll be practicing on, I have 4 of these so I can do all the damage I want in the quest for knowledge
• INDUCTION—open 35 degrees ABDC (above bottom dead center); close 41 degrees ATDC (at top dead center); duration 186 degrees.
• EXHAUST—open 81 degrees BBDC (below bottom dead center); close 81 degrees ABDC; duration 162 degrees.
• TRANSFERS—open 67 degrees BBDC; close 67 degrees ABDC; duration 134 degrees
so what way should I go for the HPI to get the most lowend while still giving a little more room on top?
I'm thinking of pushing the induction closing to 55 resulting in a 200 duration and opening the exhaust duration to 170.
Does that sound close?
Josh K. is offline
Old 02-22-2004, 10:59 PM
  #150
SlobbaTech's Avatar
If you lengthen the exhaust duration you will lose torque and gain top end power. When I tried increasing the intake (sleeve)duration, like 8* or so, I thought it had more power everywhere. if your induction port opens sooner it shuld have more bottom end power, while if you grind on it to stay open longer it should have more top end power, I thought like a 210* duration was good. You can also change your combustion chamber's shape, the taper, band width, radius of the bend/angle, and can put some grooves in it to get the fuel/air to mix better and burn more powerful b/c the rich spots shouldn't be as bad. I have only ran .12 engines so the principles will be the same for .21's but the numbers might differ.
SlobbaTech is offline
