Like Tree1Likes
"the tuning bible"
Old 07-27-2009 | 01:36 AM
  #91
M7H's Avatar
M7H
Originally Posted by keavze
my guess is the LSN still abit lean?
No, actually it's a bit rich....
Lean it a bit, and lower your idle....
Because of the rich LSN, you had to set a high idle setting, after a high speed pass, the engine is fully cleaned out, and then running a high idle until it loads up again....
M7H is offline
Old 07-27-2009 | 07:24 PM
  #92
lowey79's Avatar
+1
Lean it out a touch and re-set your idle!
lowey79 is offline
Old 07-29-2009 | 06:22 PM
  #93
In this method it mentions that if you blip the throttle and the engine idles high for a few seconds then drops (which my engine does) then you should lean out the LSN until it idles high for 20 seconds, then change the idle screw appropriately. I'm going to assume screwing in the idle screw opens the carb more (which my carb does do from my observation) and hence if i want to decrease idle i should close the carb ie undo the screw. Let me know if this is right philosophy please
Also, after changing the idle screw via this process... do you keep the LSN as is? or do you readjust the LSN depending on smoke/performance again, now that the idle is set properly...
I'm a total novice to RC so yeah... please help out a young'un
Cheers
LordAnubis is offline
Old 07-31-2009 | 08:08 AM
  #94
Hi
Run the engine for a tank of feul to get everything hot. refuel the tanks and do a high speed pass come back in and check the lsn by listening to the idle if it idles high and then drops you have a rich botoom end and should lean the LSN by 1 hour turning it in (Clockwise).
Do another full speed pass bring the car in and listen to the idle again you will notice that it still high idles but not for a long. Keep doing Full speed passes and continue to lean the LSN until the idle stays high.
now with the engine still running turn the idle screw to the left (Counter Clockwise) you will notice the idle speed drops. Set it so the idle is nice and smooth and sounds constant the clutch should not be engaging.
once you have done this the LSN and idle is tuned and you dont need to touch them.
last of all check the HSN and tune accordingly beause your rich bottom end could be hiding a lean top end
Hope that helps
Ben
BenXB8ec is offline
Old 07-31-2009 | 09:10 AM
  #95
NitroWD's Avatar
so the ideal case is that after a high speed pass when you bring the car in, the engine should drop to normal idle immediately?
NitroWD is offline
Old 07-31-2009 | 02:31 PM
  #96
yes the idle will always stay the same no rise no drop
BenXB8ec is offline
Old 07-31-2009 | 05:08 PM
  #97
Thank you for the info BenXB8ec. Really appreciate it mate !
Old 08-07-2009 | 11:32 PM
  #98
erniegarcia's Avatar
just bought a rossi .21 and broke it in.. i'm having trouble understanding the damn thing (i can't find the lsn)... let alone running it.. anyone know where i could find some pictures or videos?
erniegarcia is offline
Old 08-08-2009 | 12:08 AM
  #99
SteveP's Avatar
Rossi or Novarossi? Both have extensive information about the engines on their websites.In both engines, the low-speed needle is in the end of the slide valve, nearest where the throttle linkage attaches.
SteveP is offline
Old 08-08-2009 | 12:20 AM
  #100
Lille-bror's Avatar
Here is a VERY good video:
http://www.youtube.com/watch?v=oSmMz...eature=related
Lille-bror is offline
Old 08-12-2009 | 12:25 AM
  #101
chipo's Avatar
According to that, if you will leave the engine idle more than 20 sec it will stall?!
chipo is offline
Old 08-21-2009 | 05:19 PM
  #102
Originally Posted by SteveP
You have it mostly correct. It's not really wearing because it's thin. Both coatings will wear, but the nickel wears half as much as the chrome. Lets say for example that the NSC sleeve wears 3µm, then the hard chrome would wear about 6µm under the same conditions. The piston however, is where there's a big difference. In an engine with a hard chrome sleeve, this piston may wear 20µm, but the same piston under the same conditions with a NSC sleeve will probably wear 60-70µm. So, it's easy to see why the performance degrades more quickly in engines with NSC sleeves - it kills the piston.
If the NSC coating is applied via chemical process instead of electrochemical, it can be as thin as .3µm, whereas chrome starts about 2 to 3 times thicker, and gets multiple passes. So, the opportunity for the coating to wear through a NSC sleeve is greater if it's not applied thick enough. but the RATE of wear is still much lower when all other factors remain the same.
One other very important factor that has been overlooked is a NS coated cylinder has a specific texture which acts as a surface to hold oil which allows less ring contact with the hard surface, similar to cross hatches on a cast iron cylinder.It acts like a skimboard..(layterms) Keeping the rings from touching the cylinder as much.Lubrication is the key.
Joey Platinum is offline
Old 09-04-2009 | 03:53 AM
  #103
after a high speed pass, my engine will idle slightly higher; however if i blip the throttle, it'll return to normal idle.
if i don't blip my throttle, it'll return to normal idle after about 5s.
Hi All,
PLEASE HELP ME :-)
I have excatly the same "issue" on my engien (O.S. V-Spec blue head).
Two things you must know before I describe the issue:
When I come in to fuel, I do this only with a 1/4 throttle because it is quite difficult to get in our pit lane. And the pit lane is really narrow.
That means the engine has normal idle and it is close to stop.
But when I stop the car at the track after a high speed pass it has a higher idle.
If I blip the throttle it returns to normal idle.
If I do not blip my throttle it takes 5s to 10s to go down to normal idle.
I understand that you all recommend to lean the LSN as M7H has done:
"No, actually it's a bit rich....
Because of the rich LSN, you had to set a high idle setting, after a high speed pass, the engine is fully cleaned out, and then running a high idle until it loads up again.."
I have done this so that the higher idle stands for 15s to 20s.
And I lowered the idle.
It feels perfect after a high speed pass.
But if I blip the throttle it lowers the idle and it's really close to stop or it stops.
Same when I come in to fuel with 1/4 throttle the idle is really low and after 1 to 5 sec it stops.
Some of my colleagues told me I am to slow I shall race a bit faster this solves my issues :-)
but I hope you can recommend something better.
Thanks a lot
racer_hh
racer_hh is offline
Old 09-04-2009 | 04:38 AM
  #104
Lille-bror's Avatar
Hi.
Try a hotter plug and retune. What plug do you use now, and how much nitro?
Have you added or removed shims in the top?
Cheers
Old 09-04-2009 | 05:09 AM
  #105
M7H's Avatar
M7H
Thanks a lot
racer_hh
very good suggestion...
Well actually, what you just described is quite normal and as suggested by Lille-bror, try to put in a hotter plug (go from 7 to 6, or from 6 to 5)
When driving 1/4 throttle through the narrow pitlane, your engine will load-up...
Maybe you can also just set idle a bit higher...
M7H is offline
