Like Tree195Likes
Novarossi engines thread
Old 11-03-2004 | 08:02 PM
  #556
The stock shim is an alum .3mm I have some spare copper .1mm shims so i guess i will try that first. The pipe is a 1 piece flanged pipe so i cant change the length. To messure a pipe length you messure from the back bend of the header to the rib in the pipe body correct? Is restricting the stinger an option or is this a nono?
rcosmax is offline
Old 11-03-2004 | 08:04 PM
  #557
afm's Avatar
afm
Originally posted by InitialD
What's the length of the pipe and manifold combo? Is yours a two piece pipe? Try making it slightly longer. You could also add 0.1 mm shim under the combustion chamber head. What is the stock shims that come with the IDM?
Yeah D, we thought the same, i was suggesting a longer header. But apart from knowing what stock shims he has, it would help to also what % nitro fuel he's using.
AFM
afm is offline
Old 11-03-2004 | 08:09 PM
  #558
afm's Avatar
afm
Stock .3mm shim is good for up to 30% nitro. What % nitro fuel are you using??
Yes you can make your header longer even if it is an in-line pipe combo, just cut a silicone normal header coupler to 2mm thin slices and put them in between header and pipe. Springs we'll hold it tight, and try with one and so on.
AFM
afm is offline
Old 11-03-2004 | 08:24 PM
  #559
InitialD's Avatar
I think in Japan, racers there do not use more than 25% nitro for 1/10th scale...
InitialD is offline
Old 11-03-2004 | 08:31 PM
  #560
Thank you afm and Initial D I am using 30% fuel so the stock .3mm shim should be ok by itself? Most of the tracks I race at everyone uses 30% but this is not jmfra sanctioned racing. I will try spacing the header with the cut 2mm gasket. Still wondering if i can restrict the stinger with 5.2 mm tubing because that would be much easier than buying a new pipe.
Your help is really appreciated.
rcosmax is offline
Old 11-03-2004 | 08:32 PM
  #561
afm's Avatar
afm
So if he is currently with .3mm shim, he could use two .1mm shims to a total of .2mm head shim and will work good with 20- 25 % Nitro.Dont you think??
AFM
afm is offline
Old 11-03-2004 | 08:35 PM
  #562
afm's Avatar
afm
First try the header lenght...see results...then think about restriction of stinger.
AFM
afm is offline
Old 11-03-2004 | 08:47 PM
  #563
OK thanks very much for your help.
rcosmax is offline
Old 11-11-2004 | 01:40 PM
  #564
Default tuning rr12l3
I have gone thru about 7 tanks and the engine is still very tight. Still have to heat with heat gun in order to start it. But once started, run fantastic!!! No flame outs and lots of torque. Ballistic acceleration with low end needle leaned half a turn from stock and the high speed needle leaned almost quarter turn from stock. Now I do see a trail of white smoke when accelerating but concerned about aoil consumption. I think the engine is still rich on the high end but I had to lean out the low end in order to get the engine to idle. After almost every tank I had to turn down the idle speed to stop wheels from spinning/clutch engagement as the engine is getting stronger. Should I start to richen the low speed needle too??? Seems like when I richen the low speed needle, the car bogs and fails to idle. I am using 30% blue thunder and have no clue what the head temp is as my cheap temp gun is no good!!! Maybe someone could recommend me a temp gun that works beyong body temp!!!
rs4lola is offline
Old 11-11-2004 | 02:30 PM
  #565
The best tunning advice is to change to a fuel on par with the engine. I use Byron or Oddonell. The setting window of that blue stuff gave me a lot of trouble with my NSR.
CTurbo is offline
Old 11-11-2004 | 02:42 PM
  #566
Default Drake engine
Don't be concern of spare parts. I use to have a Mugen MT-12 piston and sleve on one of those engines. I just took off the orientation pin from the block.
CTurbo is offline
Old 11-12-2004 | 03:45 PM
  #567
Default Top / Novarossi Online Shop
Can someone give me some website (Trusty one) that selling TOP or Novarossi .12 engine please?
Seem like there's no one got those engine in stock!
thanks
Chanhonam2k is offline
Old 11-12-2004 | 05:48 PM
  #568
mckrooz's Avatar
www.nitrohouse.com
Kinda pricey tho.
mckrooz is offline
Old 11-12-2004 | 08:43 PM
  #569
suntok2's Avatar
www.dogboneind.com
suntok2 is offline
Old 11-13-2004 | 07:08 AM
  #570
Project D's Avatar
Default NS12S5 vs JPS5
Guys, gotta ask this... Which 1 is better?, the NS12S5 or JPS5... Both in 2nd hand condition but the NS12S5 is slightly better condition...
Project D is offline
