Like Tree195Likes
Novarossi engines thread
Old 08-23-2010 | 12:28 PM
  #3736
ProE's Avatar
Default 353 09
Im looking for an online store that sells piston/sleeve set for the nova 353 09.
(store must ship international)
any recommendations
ProE is offline
Old 08-23-2010 | 05:10 PM
  #3737
Default Manifolds.
Hi guys,
Which type of manifold is better..Conical or Non-Conical?
tq23 is offline
Old 08-23-2010 | 05:22 PM
  #3738
helivaguy's Avatar
from what i have learned....
conical = different diameter at each opening,more power which uses more fuel.
non conical =standard, better fuel economy and less power.
helivaguy is offline
Old 08-23-2010 | 05:25 PM
  #3739
helivaguy's Avatar
any recommendations
http://ashfordhobby.com/SearchResult.aspx?CategoryID=8
Old 08-24-2010 | 04:31 AM
  #3740
ProE's Avatar
Thanks for the info
ProE is offline
Old 08-25-2010 | 06:25 PM
  #3741
chromie's Avatar
Can anyone help me out with some info on the flash .12-3port.
Would like to know the racing temperatures of this engine, glowplug I should use. percent nitro fuel I should use... etc.
chromie is offline
Old 08-26-2010 | 02:12 PM
  #3742
any recommendations
http://www.rc-toro.com/product_info....oducts_id=1487
here you go
silverM3 is offline
Old 08-29-2010 | 08:38 PM
  #3743
jameslow's Avatar
Anyone know the front bearing size for novaroasi 359 tune? Thanks.
jameslow is offline
Old 08-30-2010 | 04:15 AM
  #3744
Mazda614's Avatar
Questions?? Running-in procedure
This is most probably a well worn topic by now, but I keen to here from anyone regarding the best way to run-in a Nova Flash .12. I would normally give the car two tanks on the bench using 15% castor no nitro and then run the car on the track with a rich setting for about 6 tanks then start leaning it out. By about tank 10 I would switch to race blend fuel and continue till race tune is reached.
One of our most experienced races prefers to do 1 tank on the bench ( race blend fuel) then tune the car just off race settings and run for approx 10 mins using the throttle to hold the engine back ( rather than a rich setting). After that it's tune to race settings and drive the car.
What procedure are you guy's using out there, that gives a well run-in engine, good power and longevity.
Mazda614 is offline
Old 08-30-2010 | 06:51 PM
  #3745
Can u guys give an opinion about the Kangaroo engine? I am looking into getting back to racing and this engine looks like has the right price
miker2209 is offline
Old 08-31-2010 | 11:57 PM
  #3746
hi, thinking of getting a conical header for my rb tj10 (modified) with 2604 pipe.
i run on a fairly small/mid track, which one do you think is best suited?
5 or 6fin?
LiL_JaSoN is offline
Old 09-07-2010 | 05:19 AM
  #3747
Geberit's Avatar
Can anibody tell me what's the technicall difference between the .12 Flash and 353 .12/C Tuned? Which motor is the top runner of Novarossi? Maybe the 353? It has better characteristics on Novarossi homepage!?
Regards, Lojz
Geberit is offline
Old 09-11-2010 | 07:42 AM
  #3748
Riketsu's Avatar
Hey guys,
I am looking for a RB .12 Crankcase (R3/T9/T10/M3). Please let me know if you have one lying around in your pit box.
Thanks.
Riketsu is offline
Old 09-11-2010 | 04:47 PM
  #3749
BBQboy's Avatar
Originally Posted by Riketsu
Hey guys,
Thanks.
i do have one but it's got a chip down through the carburetor hole i haven't tested it so that it would give me any probelms
BBQboy is offline
Old 09-11-2010 | 08:03 PM
  #3750
Riketsu's Avatar
Do you have any pics??
How did that happen?
Riketsu is offline
