Novarossi engines thread
#1921
Originally Posted by THE DOCTOR
Yes, they show it on Fusion motorsports web site. It shows 2.9 HP and that is pretty high.
I took a quick look but I can't find anything about this engine...maybe I looked to quick :P
#1922
Originally Posted by team novarossi
where exactly?
http://www.fusionmotorsports.com/NewStuff.html
#1923
I tried the 12-5CT today. It wasnt run in properly but you can see it was a real beast. I was using 16% nitro but I think when its run in and with 25% it will be pretty awsome. I will have to see how it compares to the Murnan CRF
#1924
does anyone know anything about n21r2000 engine by novarossi? they say they are 7 port but seem awfully cheap. are they reliable, and worth the money or no?
#1925
Ant body here ran the new Collari/Novarossi 35 plus 21
#1927
Questions related to the Novarossi N12LL5 engine...
Hello Everyone,
I am new to this forum, I hope this is the right thread for the questions I have. I have two questions related to the Novarossi N12LL5 engine (the "Tuned" version):
1) Does anyone have the manual for this particular engine (not the exploded-view document, this I have downloaded it from Novarossi's website)? If yes, would it be possible for me to obtain a scanned version of the manual (in PDF format perhaps)? Thanks.
2) For a 25% nitro, what should be the factory standard shim thickness under the N12LL5 head?
Help/answers to the above two questions are much appreciated. Thank you.
Warmest regards,
C Y Poh
Warmest regards,
C Y Poh
#1928
For 25% you will need to add .10 shim and you should be fine.
#1929
hi cy,
if i remember correctly, the correct shimming should be around 0.4mm. (0.3mm+0.1mm).
by the way, where did you managed to buy this engine from ? thanks...
#1930
Hi everyone,I have N12 LS5 engine will you tell me guys what's the factory settings of this egine? Thanks.
#1931
I've done a couple searches and turned up nothing. Does anyone know where to get parts for a Top 21 BF? All I need is the rod bushing and whatever holds it in place. Mine came apart at my last race, and that seems to be the only damage. Is it the same size as in other rossi motors?
#1932
@all
which plug do you normally use on the .12 Plus-3 Novarossi engine?
#1933
Originally Posted by jaykay
@all
no. 7
#1934
http://www.amainhobbies.com/index.php/cPath/1_68_162
Nova parts are the same.
#1935
Location: Cebu City, Philippines and Ocala, Florida, USA
@all
