Novarossi engines thread
#1576
I am trying to find out what type of Novarossi i have:
It really looks like an RS12S1X , except for a bit different casting and this one has three mixture screws no lettering on top of cylinder head and a big M (maybe mugen?) on the front of the carb. I can post a picture if needed.
#1577
Check if the sleeve sits on top of the crankcase (MT12) or flush (Mr12)
#1578
Originally Posted by no4hitter
Is there anything out there to help get the melted foam off of my polished tuned pipe. What is the best way to keep it clean. Thanks
#1579
That's why I love Mielke's chrome plating.
My pipe is a year old and look like new
#1580
Hey guys,
I am running a N12LS3 on my 710. A new track opened with a fast long straight and also fast curves. Should I be using any head shims for better performance? If yes, how many mm thickness? Weather here is around 30 Degrees Celsius. Any recommendations? Thanks for the help.
#1581
Originally Posted by aaalp
Hey guys,
#1582
Plug help?
I have a NSR12S5. I'm running on the east coast in a slew of heat & humidity (85-95 degrees F and above). I have a few novarossi plugs, but an not sure should I be running a hot plug (CF5, I think) or colder (CF7). Any thoughts?
Also, I'm trying to break this new p/s in. I seem to be having a few carn problems that I can't figure out. It will run fine, then it seems like the fuel line looses pressure. I can see justa bit of fuel right by the carb inlet, but nothing else is coming thru the line. I checked the pipe, lines, and tank for leaks, and didn't find anything. I thought it could be I need to richen the low end up a tad, but I'm not sure. Any thoughts?
#1583
C5TC -C8TC, the last C meaning "Caldo" which is Italian for hot. These plugs have a short body and heat up quickly
C5TF - C8TF, the F meaning Frigo= Cold. These have a longer body which heats up slower and dissipates heat.
When I was racing in Atlanta, I always used C5TF up to 90 degrees and C6TF above that.
the 7-8 plugs are for .21 engines.
#1584
Originally Posted by stefan
Nova has two ranges of plugs:
#1585
The M on the carb is Mugen, so it's a MR12 or a MT12.
So, where can i get parts for it, like a piston/sleeve or conrod?
From what ive read these are almost the same as other Novarossi engines, but which one? the RS12S1X?
#1586
Does anyone know where i can get a Novarossi 2630 inline exhaust system from
#1587
#1588
#1589
Looking for NovaRossi on-road .21 Piston/Sleeve and crankshaft. Please email with price/info/pic to webznet at yahoo dot com.
#1590
Just how tight are these novarossi engines?
I was getting a used one from a local club member who re-pinched it and i could barely turn it over with vicegrips on the flywheel. The flywheel actually slipped on the crank even though i tightened the clutch nut real good. I killed TWO starter boxes trying to break it in. (preheating also of course)
I am curious because i bought a new one (rs12s1x) and it should arrive in a few days.
