16% for .21 engines?
We used 16% with the JP Black Mod Eagle 9S at 301 Raceway and it worked great. Vincent Jackson TQ'd using that combo. We left the head clearance the same/normal so that we could run a little leaner without detonation. Performance was great and fuel consumption increased +1 lap from 20% and +2 laps from 25%. IMO it's the best way to improve runtime with the super hot mod motors.
And I should expect my engine to run a little warmer when running 16% vice 25%?
for my case, when i use 16% on my engine that is tuned for 25% and shim for 25%, the temp goes lower and i need to lean the high end to get the power. the temp diff range is like 10-15 degree c! this is for my .21 off road engine!
well if you shim the engine on 16% then yes it should run hotter than with the 25%...
