vega conical plug
Make sure the novarossi has a head that is designed for conical plugs. If it has the correct head, install the vega plug, and start the engine. If the plug shows no signs of leaking fuel around the plug, you will be good to go, as long as the plug has the correct heat range. Hope this helps. Richard D
