OS Speed 12XZ engine ~~FULL PHOTO~~
#106
The funny thing about the ROAR rule is that they measure the length of the stinger from the tip to where it meets the canister at its furthest point. IFMAR and EFRA measure the length of the stringer itself, no matter how far it sticks in or out of the canister. They measure it from inside the stringer (with something like a exhaust spring tool). ROAR needs to look into this a little further. DAWN!!!!
#107
I actually talked to the ROAR fuel tech director about this yesterday. He measures the same way, not by how much stinger is exposed outside the pipe. Apparently, the 1050 has too short of a stinger even when measured for total length. I have told O.S. about the ROAR rule, we'll see if anything gets changed for next year.
Told ya, "Dr. Socko KNOWS!"
#109
Hey guys, aside from the MSR pipe and the 1050, any other you have tried? I read a few posts back that some had tried the 2630, I guess I'll start there.
Regarding glowplugs, can someone make a side-by-side comparison of P7 vs RP7 glow plugs aside from price? I don't want to assume that since they cost more, they are better. Look at novarossi ultra plugs, they cost alot more, yet I dont see them anymore for purchase because normal were better.
#111
XZ used OS RP6, can OS P6 be used?
#112
#113
I run my XZ with P6.
Getting a P7 to run it through later.
Anyway what are ur final needle setting for ur XZ? .
Expecting to see some different range tuning .
#115
What temperature range are you guys getting with your xz motors?
Im running a P7 plug and I register temps of 110-120 degrees celcius ... but if i lean it out, i get heaps better performance but temperatures reach 120-130 ... is this considered safe still? Ive heard of others running their motors even higher around the 140-150 range ... with still a nice thin trail of smoke
#116
#117
might be the wrong post but what pipe u recommend for a serpent 733 with a os 18tz? need suggestions
#119
BUMP
I also wonder about legal pipe´s for the OS Speed !
Anyone ???
Anyone ???
