-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   novarossi onroad engine choice?? (https://www.rctech.net/forum/onroad-nitro-engine-zone/265712-novarossi-onroad-engine-choice.html)
out-of-control 01-07-2009 12:55 AM
there is not much difference in price but I cant decide either the novarossi 353 tune or novarossi 3sct tune? running in a xray NT1.
any difference in performance with these engines??
ps I cant go the murnan modified as our currency is very weak at the moment hence very expensive buying in us dollars:(
any suggestions would be appreciated:)
novarossi OZ 01-07-2009 02:55 AM
Both motors are good,
pricing not much differance,
either motor will get you right up there...
or ozspec modified 353:sweat:
regards Aaron
Pattojnr 01-07-2009 05:20 AM
regards Aaron
still waiting for the novarossioz site Aaron, any ideas when ? cheers.
JayL 01-07-2009 09:47 AM
If your track is BIG, most time spent in second, then go for the 353.
If your track is smallish, most time spent in first gear, go for the 12-3sct
HoboShop 01-07-2009 02:53 PM
for 30-40 dollars more you can get the murnan.
353 tuned $440-470
murnan modified 353 $500.00
But the murnan 353 is a much overall faster motor than the 353 tuned:tire:
novarossi OZ 01-08-2009 03:29 AM
Patto,
how are you,
I know, i have been flat out with novarossi products that the website is taking alot loger then would have liked..
but it will be soon, promise...
353 ozspec modified $599.00aud
regards Aaron
Nitro-Racer* 01-08-2009 05:07 AM
i have been having the same question myself about which one is more suited to my track needs. i would like to know how differently the two engines compare. which one is the smootest? i feel like my 3sct is a little bit sharp.(when i say comparinson of the two i mean the 353mmm vs 3sctmmm):nod:
G87z 01-08-2009 04:15 PM
I also am wondering which engine to choose but I have the 353,3sct, and the JP Eagle 12 TL-3T. All nova based. But I just cannot choose which engine to get. Price currently not a deciding factor. I am just looking for the best engine out of the 3. Any input?
Thank you.
Riketsu 01-08-2009 04:28 PM
Thank you.
If your planning on getting the 353 or 3sct Murnan modified, then I'd say, forget about the JP. Between the 353 and the 3SCT there isnt much difference. I'd suggest to go with the 353 because it feels smoother than the 3SCT.
G87z 01-08-2009 05:20 PM
I am going to stick with the stock version because i do not need the modified for my track. Any reason why you suggest to forget about the JP?
HoboShop 01-08-2009 05:23 PM
It depends on the size of the track that you are running on.
The mm+12sct will have the most lowend and midrange
The mm 353 will be smoother than the mm+12sct and have a tad bit more top end.
The jp eagle tl3-t will have less bottom end than the mm+12sct and the mm353 but it has a stronger midrange than the mm 353 and less than the mm+12sct but where the eagle tl3-t comes in strong is on the top end it has the most top end speed of any more on the market at this time i am telling you the rpms this motor produces is limitless. I race at 301 racway as you know are straightaway is one of the largest in the usa and we have ever motor you could think about down here but the eagle still pulls past any motor as of know it still holds the top speed record clocking in at 67-68.
mm +12sct= $500.00
mm 353= $500.00
jp eagle tl3t= $580.00-650.00
