best Pipe for Novarossi NS12TS1 0.12 engine
Looking for one pipe that best match this engine. Pls advise. tks,
bro... sorry for using ur thread also... cause i also just got myself a ns12ts1 ZAC and was thinking which pipe will suit. i will be using skyline....
Can u share where u get it from? is nova 2630 a good match?
It will all depend on the track your going to be running on.
Here are the pipes that will work for your engine (in the order I'd recommend em): -MAX 2602 -Novarossi 2630 -Skyline VR12 Plus Other similar pipes that I believe will also work are: ATS 2621, JP 2620, Novarossi 2601, RB 2604. |
thanks for the recommendation.
I'm eyeing on the Nova 2630. But what is the different between 1. Novarossi 2630 With Conical 6 Fins Manifold For .12 and 2. Novarossi 2630 With Conical 5 Fins Manifold For .12 Pls advise. tks./ |
I would go with the Novarossi 2630 tuned pipe as it was designed for Novarossi engines. The different conical fin headers are for low end and high end performance. Someone may correct me on this but I believe there are 3, 4, 5, 6 and 7 fin conical headers available for the Novarossi 2630 tuned pipe. This aollows for a wide range of tuning based on whether you are running on a short, medium or long track and if your looking for more low end power or top end speed.
Regards, Speyederjedi |
Originally Posted by viperviper
(Post 5230162)
I'm eyeing on the Nova 2630. But what is the different between 1. Novarossi 2630 With Conical 6 Fins Manifold For .12 and 2. Novarossi 2630 With Conical 5 Fins Manifold For .12 Pls advise. tks./ 5 fins = shorter header = better top end power |
Originally Posted by Speyederjedi
(Post 5230240)
Guy's
correct 5- relate's to short --more top end 6- medium --- good all over 7-long manifolds ---better bottom end regards Aaron |
hey, thanks all. Just ordered a 6 fins pipe. Will let u guys know if it's good. cheers!
pipe
is the kawahara pipe suitable for dis engine..
The JPblack 2620 will wake up any Novarossi based engine:nod::nod::nod:
How abt novarossi 12 size outlaw pipe, can it be used on this engine?
And how does it compare to the Novarossi 2630 pipe? Pls advise. |
Anyone can advise? thanks!;)
My suggestion is stay away from Outlaw pipes because this engine was designed in the beginning for Sedan pipes. In my own opinion, even if it was allowed I would not match up a .12 engine with an Outlaw pipe. Hope this answers your question.
but why? what is the reason for not matching it to a 0.12 engine? what will be the effect if u still insist to match this outlaw pipe to this engine?
The only other pipe I would suggest is the 2601 for a longer track with more straights. You can use the 2630 for more bottom end power on a shorter track to get out of the corner faster. I wouldn't run an outlaw pipe, the performance won't be there and the engine could run a little hotter.
(Post 5256503)
Hope this helps, |
so there is nothing good about this outlaw pipe... i thought it was a good 0.12 pipe. :o
