Old 11-07-2008, 09:11 PM   #1
Default nitro % in a ninja mr12to1a.
thanks for looking guys. i have a new ninja mr12to1a and was wondering what nitro % you guys were running?
i have been using 20% werks race blend. I broke in the motor with the 20%.I ran 3 tanks idol then ran 8 tanks on the track getting closer and closer to a sorta of a race tune"215-235"f. think thats broken in enough to race it?
im running out of the 20% and have a new gallon of 30%. would it be a good idea to change %? do I have to shim the head and change turbo glow plug also? thanks again
ROLLINGaFTGT is offline   Reply With Quote
Old 11-10-2008, 07:43 AM   #2
Rolling...
I use 30% on mind, but I would recommend you stick with 20%. if that is not the case and you cannot replace the fuel, than you need to add shims to the head. I went with .5 mm worth of shims. Then, I went with a medium or colder plug. I use the ninja #7 plug. You also will have to retune the gine and be carefull with it. Don't go straight by temperature.
MTX 4R
OS 12TZ Speed Spec II
OS 1040 One Piece Pipe
HPI R40
OS 12TZ Carlson Mod
Ninja One Piece Pip
SasonRC is offline   Reply With Quote
