-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   INS vs. INS? (https://www.rctech.net/forum/onroad-nitro-engine-zone/238206-ins-vs-ins.html)
Krazy8 08-20-2008 02:33 PM
INS vs. INS?
There are several INS air boxes available, but are they all the same? Does one have an advantage over the others?
I'm curious since I've only seen the design for the Novarossi (blue) INS.
Team Kamikaze 08-20-2008 03:11 PM
Chris,
All the Induction Noise Suppressor boxes serve the same purpose .
INS box is originally designed by Serpent, In 1995 IFMAR, the World organization for RC racing, asked the manufacturers to come up with solutions to reduce the noise-level of 1/8 scale gas powered racing cars. Serpent took up the challenge and in close co-operation with the University of Delft, developed the universal Induction Noise Silencing Box, the INS-BOX. In combination with an effective (*) exhaust silencer, the INS-BOX is able to reduce the overall sound level with up to 4 decibels. If 10 cars would be using the INS-BOX at the same time, like in a race, the overall noise-level would drop with 5 to 6 decibels!
Source: http://www.serpent.com/product/200305
Krazy8 08-20-2008 03:22 PM
Right, but does one design have an advantage over another or do they all flow air about the same?
Krazy8 08-20-2008 03:27 PM
Team Kamikaze 08-20-2008 04:14 PM
They are all the same, they function the same and there is no advantage over any other brand, the only difference is the color.
JayL 08-20-2008 04:18 PM
the mugen one works on 1/10 touring better...also their are 2 versions of it : the old version has no holes drilled inside the cap, the new ones do
Renault_Tech 08-20-2008 11:46 PM
Where can i get a 1/10 INS from?
Uga 08-21-2008 12:09 AM
But I think in the mugen box you can place only mugen filters, which are quite expensive.. I'm using the blue novarossi box with offroad foam in it, you can change the filters in it not even removing it from the carb, just undo the 3 screws at the top. I prefer nova against serpent, as it's fixed by screws, not clips. You will see so many guys using tape to secure the serpent ins box :D
You can get them at kamikaze if you are in states or from rc-mushroom.com is asia.
JanisK 08-21-2008 09:59 AM
Only advantage of Mugen insbox - it fits better under the body (serpent and novarossi sometimes touch the roof of body), also mugen version is the only INSbox you can put on RB R3 engine
Roelof 08-21-2008 10:42 AM
The Serpent is the largest in diameter. Because of that you can get some problems to leave some flesh in the body, beside that, on some engines it will not fit because the main needle is to close to the air intake. Older Picco's like the G1 for sure has this problem.
Picco designed his own one, it is smaller and has less but larger holes inside compared to the Serpent. This seems to give a better airflow to the engine.
I believe the Nova box is the same size as the Picco.
The Mugen is compleetly different, it creates more noise and does give more air and so less drivetime but at this moment it is the only one fitting .12 engines.....
