Orion CRF .12 2008
Old 12-15-2008 | 11:25 AM
  #61
expat's Avatar
Default CRF 21 2008 Onroad
Hi All,
What Picco Version is the CRF 21 2008 Onrad based on? Evo2 or 3?
The Crankcase looks like an Evo2. How about the timing?
Cheers
TP
expat is offline
Old 12-15-2008 | 09:08 PM
  #62
GREGORY!'s Avatar
does anyone know if team orion will produce a new engine for the next year?
and what size will that be?
thanks!
GREGORY! is offline
Old 12-23-2008 | 11:30 PM
  #63
Nano's Avatar
Team Orion engines may be similar to Picco but actually have a lot of differences, mainly because of the CRF technology. So you can't say it's based on Evo 2 or Evo 3 design because it is a mix of technologies. For obvious reasons we are not going to change things that work perfect the way Picco makes them...
Timing on the crankshaft is different because of the CRF technology and the liner timing is also slightly modified.
The engines are continually updated so you can expect some updates in 2009.
Nano is offline
Old 12-23-2008 | 11:40 PM
  #64
Sp Racer's Avatar
Nano, have Orion/CRF addressed the con rod issues that the picco engines have?
Sp Racer is offline
Old 12-24-2008 | 01:14 AM
  #65
keavze's Avatar
what would that be?
premature failure?
keavze is offline
Old 12-24-2008 | 01:17 AM
  #66
Sp Racer's Avatar
Originally Posted by keavze
what would that be?
premature failure?
Well, lets just say a certain Picco based engine I use....we are up to engine number 10 now and counting ( have pics )
Picco con rod = crap
Sp Racer is offline
Old 12-24-2008 | 01:25 AM
  #67
keavze's Avatar
what actually happen to the rods?
my previous 'picco' engine fails with the conrod brass bushing (part where it connects to the crank) breaking into pieces.
keavze is offline
Old 12-24-2008 | 01:28 AM
  #68
Sp Racer's Avatar
Check your PM
Sp Racer is offline
Old 12-31-2008 | 02:18 AM
  #69
jameslow's Avatar
so anyone tested? is the orion rod more lasting or they are just the same? Btw idm rod can use on orion .12 2008?
jameslow is offline
Old 12-31-2008 | 08:27 AM
  #70
RC MARKET's Avatar
tested in my NT-1
this is my first engine ,first time race had very very fast !
my friends said my car speed no.2-3 !!
RC MARKET is offline
Old 01-18-2009 | 10:02 PM
  #71
fatboy's Avatar
are you using the CRF pipe as well.
fatboy is offline
Old 01-19-2009 | 01:25 AM
  #72
GREGORY!'s Avatar
maybe nano can answer this to you.i think that the rod isn't exacktly the same like picco but you can put one in there.just waiting nano to be sure!
Originally Posted by RC MARKET
tested in my NT-1
rc market what pipe do you use?2647?manifold?
GREGORY! is offline
Old 01-19-2009 | 01:44 AM
  #73
Nano's Avatar
Afaik the conrod issue is an old one, the CRF engines never suffered from it. Materials used, manufacturing processes etc. are regularly checked.
A specific part will not be problematic for a long time, it will be updated very fast because engines are used all the time, it should not make it to the market.
Of course you can never rule out a problem with mechanical parts, but everything is done to minimize the chances of this occurring.
Nano is offline
Old 01-19-2009 | 01:50 AM
  #74
GREGORY!'s Avatar
thanks nano!1 more question!can someone put 21. orion rods in the picco 21 engines?i have noticed that orion has a new style rod .it has a groove in the low bushing to take more oil in there!right?
GREGORY! is offline
Old 01-31-2009 | 01:22 PM
  #75
RC MARKET's Avatar
I'm used #ORI88009 pipe
in mid size track very very fast with linear to control ,
pick-up respond no problem , like fit my EP Car style ,
don't lose NOVA 353 turned & OS Speed engine !
