Old 03-28-2008, 07:21 PM   #1
jameslow's Avatar
Default Crank shaft sealant!
Hi guys,
Can I check, for those guys who mod their engine crank shaft, what sealant did you all use to seal up the hole in the crank shaft to make it smooth?
Thanks!
Waiting!
jameslow is offline   Reply With Quote
Old 03-29-2008, 03:11 AM   #2
stefan's Avatar
Send a message via AIM to stefan
Arexxon Motorsil D
stefan is offline   Reply With Quote
Old 03-29-2008, 03:42 AM   #3
RayJ's Avatar
Permatex Red RTV works just fine.
RayJ is offline   Reply With Quote
Old 03-29-2008, 10:18 AM   #4
stefan's Avatar
The problem with the Permatex is, thaqt is is not liquid and you have to smear it in, which will never give you a smooth surface. The Motorsil stuff is what the manufacturers are using. It's liquid and it flows out like a mirror.
Old 03-29-2008, 03:55 PM   #5
RayJ's Avatar
Stefan....can't find Motorsil D listed anywhere in the US.
Old 03-30-2008, 08:42 PM   #6
jameslow's Avatar
Btw is it really very useful to seal up the crank shaft? Overall show great improvement to the engine? Bec from what i know, by modding the crank is the area u can get more power than modding the sleeve! Im i right?
Thanks!
Waiting!
Old 03-30-2008, 10:28 PM   #7
stefan's Avatar
Thanks!
The silicone is only used when you have a drilled / lightened crank. The deal is that you remove weight from the crank ( towards the clutch side) and then you fill the void with the much lighter silicone, to keep the crankcase volume about the same.
To get good, usable power from an engine, you'll have to modify the entire engine, crank timing and all of the sleeve ports, otherwise you'll have a funny running engine.
Old 04-01-2008, 10:57 AM   #8
JetMD's Avatar
I have used red permatex a few times with great success. It is hard to get perfectly smooth but if you cut a tongue depressor to the right size and use the rounded end, you can get a nice smooth flat ramp out of it. You'll need something to keep the permatex from sticking to the tongue depressor. I use spit but you can also use a soap and water solution. Would love to know where to find the liquid stuff stefan is talking about in the US. But until then, do what you gotta do.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 04-01-2008, 01:16 PM   #9
Moderator
mxwrench's Avatar
Threebond 1211 is what I use. Flows perfectly smooth. It is white colored.
Only downfall is it takes about 24 hrs to harden fully. Use of heat will speed things up a bit (max 140deg f.)
Many US modifiers are using this stuff.
BK
Brian Kinney
TLR Design Engineer
2016 Sponsors: Team Losi Racing, AKA Tires, Orion, Nitrotane, Horizon Hobbies, Fast RC Paint.
mxwrench is offline   Reply With Quote
Old 04-01-2008, 01:34 PM   #10
JetMD's Avatar
That stuff looks great. I think i'll give it a try. Thanks!
www.vorra.org
MINO Racing
Crank Shaft from OS SPEED V-SPEC atomapapa R/C Items: For Sale/Trade 12 10-02-2007 09:13 AM
HoBao Hyper .21 crank shaft.. TeeKuang Malaysian R/C Racers 5 08-28-2007 08:36 AM
Standard crank shaft to SG crank shaft adapter? Fred Perkins Onroad Nitro Engine Zone 5 04-02-2007 11:53 PM
Red RTV sealant to crankshaft mrgsr Onroad Nitro Engine Zone 1 12-11-2006 06:51 AM
Why isn't the Sg crank/shaft the standard RayA Nitro On-Road 5 11-17-2002 09:57 PM
